Question about Dryers
Tumble dryer drum only starts when i start it first by hand
My white knight condenser tumble dryer only starts when i turn the drum by hand, after that it goes round untill the reverse action kicks in and the drum stops, i then have to push the drum alittle and it goes round again
  • Anonymous Mar 12, 2014
    Hi, my bosch classixx 6 Tumble dryer is making a ticking sound as the drum turns. It has started just this week. Anyone any ideas??
  • 63 Answers
Starter capacitor went bad on motor... replace
Posted on Mar 13, 2009
My white knight condenser tumble dryer keeps
is it just shutting off or is it tripping ur breaker?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 13, 2014 | Dryers
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
How to replace door handle on a White knight tumble?
quicker and easier to replace the door, cheaper in the long run.
Jul 23, 2014 | White Knight Press Genuine Tumble Dryer...
White knight gas tumble dryer
On most clothes dryers, whether gas or electric, the drum is rotated by a belt, which runs off a motor. The most common reason for it not to tumble is that the belt has broken.Someone needs to replace that belt. If, however, when you start it up , you do not hear a humming sound whilst pressing your ear to the top of the machine, the motor itself may not be turning, which could also be the problem. Be blessed.
Dec 15, 2013 | Washing Machines
Hi my dryer is heating up but the drum not turning help its a white knight small tumble dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
My white knight condenser dryer doesn't heat up anymore what do i need to replace?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Mar 25, 2010 | Dryers
Wk767 tumble dryer
it is the motor run capacitor it happened to me i bought a replacement in maplins for about £3 or £4.
Mar 09, 2010 | SNK Knight 43AW Electric Dryer
Dryers Logo
628 people viewed this question
Top Dryers Experts
