Soniq set top box reset - Televison & Video
Why does it display "no signal" when requesting to watch tv ?
If I know the Sonic TV model, there is NO TV tuner built-in.
What sources have you connected to which port ?
Typical sources are
(a) Cable using Set top Box using HDMI
also see
Soniq tv problems
Mar 22, 2016 | Televison & Video
Universal remote code for soniq 55" S55V14B-AU ?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 19, 2016 | Universal Televison & Video
I have a one for all urc 3415 need the codes for soniq
0271,0225. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Jul 29, 2015 | One For All Televison & Video
Can i get the code for a digitalRM810 remote to work on a Soniq TV the remote lost was a GT112 remote
0281,0288,0270,0259. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Oct 19, 2014 | Televison & Video
I need the TEAC set top box model DV-B400 code for a audio soniq unversal remote
029,022,025,021. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 12, 2013 | Televison & Video
Soniq tv problems
Check its input connections, and input selections. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window.
May 11, 2013 | Televison & Video
Unlock Region Code/Instructions - Request
Just spoke with Soniq's help line in Australia. They gave me the instructions below. I have not tried them yet as I have boxed up the TV already and I am moving out of the region. Good Luck.
Unlock instructions for Soniq L37V11B
  1. Turn on TV
  2. Set to DVD Mode
  3. Press Open/Eject
  4. Leave DVD door open
  5. Press 5168 on remote
  6. This should open a Factory Menu, scroll up/down to Region Settings
  7. Change Region to 0, press Enter
  8. Press Open/Eject on remote to close the DVD door.
Soniq Help line in Australia 1300765663, option 2 then option 2
Jul 07, 2012 | Televison & Video
Set up code soniq
go to www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jun 21, 2012 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
