Lg tv child lock
I have a lg tv ct14f60kg ..my tv cannot serch other cahnnels ..it jist serch 42 channels
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help.
Posted on Apr 23, 2013
  • 14 Answers
SOURCE: HOW DO I turn off
you might need LG service reomte to remove child lock
Posted on Aug 17, 2010
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
SOURCE: Un lock child Lock.
HAL DIE EPROME YT SIT AN TV VIR EEN SEC EN SIT EPROM TRIG EN SIT TV AN
Posted on Jan 31, 2009
dcramer531
  • 1654 Answers
SOURCE: i have a goodmans x pro 42 inch flat screen tv and
http://www.e-repair.co.uk/ If all else fails this site offers help and you can contact Goodman on thier web site.
www.goodmans.co.uk Although all televisions have a slightly different adjustment process, the overall steps for removing the child protection lock from the TV is essentially the same.
Bring Up TV Menu
  • Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features
  • Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
Remove Child Protection Lock (V-Chip)
  • Highlight the selection "Remove Child Lock" and press "OK" (depending on the television being used the selection button may vary as other button options are "Enter" and "Select").
  • Type in the four-digit code used to create the child lock in the first place when prompted. If you do not have the four digit code (or do not remember it), the only other way available to remove the child protection lock is to reset the television. Look in the TV's user manual for exact instructions as to how to reset the TV. Doing so removes all saved features and menu adjustments, including the removal of the child lock.
Exit the TV Menu
  • Close out the menu once you have finished. Depending on the television being used the method of closing the menu is going to vary. Typically the button selection used is "Menu" or "Exit."
Although the child protection lock is an extremely helpful feature on most televisions when raising children (or when certain programming is not desired), there may come a time where the child protection lock is no longer needed, in which case it needs to be turned off and deactivated on the TV. No matter what the television brand or make is, the method of turning off the child lock (or V-chip) is relatively the same
Posted on Dec 25, 2010
joeguest2
  • 2080 Answers
SOURCE: Hii i need to unlock
Try entering code 0000 or 1234 for the child lock.
Otherwise try holding down the DISPLAY key on the remote or on the front of the tv for 10 seconds to disengage the child lock.
Otherwise unplug the power cord and leave it out for a few hours to clear the internal memory and reset to original settings.
Good luck and please post back if this helps.
Posted on Jan 25, 2011
My RCA E13344 Tv is connected directly to the cable wire (no cable box) on the menu i set the tv to cable tv and serch for the channels. After the serching is done the tv stops at channel 7 instead of...
I'm sorry for the difficulties you're experiencing in getting the few channels. I suggest that you unplug the TV to perform a power resetting and then perform auto programming to resolve the issue. Please let me know if the issue persists.
Dec 29, 2011 | RCA E13344 13" TV
How to open child lock on cineplus LG TV manually as remote is not working
Jan 28, 2011 | LG 42LC2D 42 in. LCD HDTV
I want to know the solution to my tv it displays but i cant watch station on my tv it displays unlock child lock
try to go to main menu select the child lock and unlock it has a password the default password is in the manual
Oct 12, 2010 | LG 42PG20 42 in. Plasma HDTV
HOW DO I turn off the child lock on my lg tv cause i cant change channels
Aug 17, 2010 | Televison & Video
Cannot access 'channel'' menu in samsung DTV menu to carry out retune. The menu jumps from 'sound' to 'setup', the 'channel' icon is greyed out and cannot be accessed.
This is becouse you had done some Channel Child Lock first open all child lock than try to tune channel.Or possible that you are in some other input mode.select TV mode than you can try.
Jan 22, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
Apr 10, 2009 | Televison & Video
Un lock child Lock.
Jun 13, 2008 | Akira EPM-420A 42 in. Plasma Television
CHILD LOCK ON
go to the lock option in the menu screen, either press 0 0 0 0 or 7 7 7 7 that should unlock on lg sets anyway
Mar 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
My Tv says Keys locked
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
Nov 11, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
