Question about Samsung NC110 Netbook
I cannot open my laptop. The monitor of my laptop is not opening
    Problem Solver:
  • 4 Answers
Probelm in vga or screen. bring our service center ,
Multiware Info System
#163,North Usman road,
T.Nagar,Chennai-600017.
9841602538,9840433727opp: joyallukas jewellery
Posted on Jun 13, 2013
When I shut my laptop monitor goes off and won't come on until I open laptop again?
Change display settings in energy management to NOT turn off when closing the laptop
Oct 20, 2012 | Apple Cinema Display 23" HD Monitor
I have a dell laptop with windows 7. i just purchased monitor samsung b2330 23". everything looked great. now for some reason, everything looks normal on my laptop, yet on the monitor looks like it is...
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. To designate the primary display, on the Monitor tab, click the icon that corresponds to the monitor that you want to designate as the primary display, and then select the This is my main monitor check box.
  3. Select the screen resolution and color quality for each monitor that you're using.
Oct 03, 2010 | Samsung Computers & Internet
While at home I plug a wide screen monitor into my Dell studio 1737 Laptop. As long as I keep my lid open the icons and print on my monitor are the right size. When I close the lid, icons and prints get...
You appear to be cloning your internal LCD and as long as it is active, the resolution setting for the LCD is also controlling the resolution of the external monitor. When the LCD is closed, then the default resolution of the external monitor is being used by Windows 7 (It apparently has autodetected the size of the monitor and knows the Highest optimal resolution it will display.) The higher the resolution, then smaller the icons.
To resolve, go to display properties and check the resolution of the internal LCD and then set the External display to the lower resolution.
You should be able to wake the system with an external keyboard, by pressing the spacebar, if the system is sleeping
Jul 24, 2010 | Dell Studio 1737 Laptop
Blank desktop monitor
Try booting into safe mode and reinstalling the drivers for the video adaptor and monitor. Maximize the display settings after rebooting in normal mode.
May 23, 2009 | Compaq Presario Notebook
I usually dual monitor and have programs open on both. now that i am at home i do not have my second monitor only my laptop. when i go to open a certain program it opens on my "second monitor" that isnt...
You should go to the display properties on your laptop while at home and disable the dual monitor setting. You should then have all programs open on your laptop screen and not on the secondary monitor. If running XP, right click an open spot on desktop and select Properties. If running Vista, right click an open spot on desktop and select Personalize. Go to Display Settings, select the second monitor and uncheck "Extend the desktop onto this monitor". Hope this helps.
Apr 25, 2009 | Computers & Internet
Hp pavilion ze2000 video out
you may have the output set to "dual monitor". when you open a window, it will open first on your default monitor. if you can move your mouse among both the laptop monitor and the other monitor this is what the issue is. without more info, not much can I do to help.
Aug 16, 2008 | Computers & Internet
LCD Problem
hook up the ibook to a external monitor, via the monitor cable, if it comes up, you know its not your motherboard. There should be a monitor icon on your keyboard to switch from laptop monitor to external monitor, it could have been pressed by accident.
Jul 16, 2008 | Apple Computers & Internet
A Open monitors
replace the power cords
Jun 09, 2008 | AOpen Computers & Internet
Display panel on dv9040us has opened up
Could you post a picture of your problem? The issue is probably that the screws holding the monitor mount to the rotating piece have stripped and come out, and the small piece that is meant to stay screwed in is spinning freely. This can spread that area out and pop open the monitor casing.
You can pop off the small rubber "feet" that go around the monitor to gain access to the screws. You may be able to position the monitor in the correct angle and screw it back in with a precision screw driver. If this was the problem then this is most likely a temporary fix. If the screw has come out once, then the groove is stripped and it will happen again. You'll either need a new screw or most likely a new hinge in the future.
Regardless, try posting a picture and I'll be able to help you more.
May 12, 2008 | Computers & Internet
Neovo F-417 failure
When troubleshooting another problem with this monitor i had it open and noticed that all thought this monitor has a "fixed video cord" once the unit is opened up it actually plugs in just like any normal video cable for a monitor. If the monitor video cable is the problem(bent pins, twisted to much, left kinked) then replacing it is an option. Simply open the monitor carefully(so as not to break any clips) and remove the EMI Shield. Once you do this you will be able to see where the video cable plugs into the monitor and replace it.
Jan 29, 2007 | Neovo F-417 17" LCD Monitor
Samsung NC110 Netbook Logo
97 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
