Question about Okia 420w UL Approved ATX Computer Power supply (OKIA420ATX) Power Supply
Friends custom-build PC has no power
Working on a fiends custom-build PC that doesn't have any power. No fans,no lights,no noise...nothing.
I tried the Okia 420W PSU in another PC and works fine. Bypassed the on/off switch still no power. Is the Asrock k7vm3 mobo the problem or something I'm missing here?
Thanks in advance...
  • dubslurplus Mar 13, 2009
    Bingo! Took mobo out of case and it came to life. Put it back in case and started adding hardware one by one then testing to see if still had power and problem occurred once front USBs were added. Thanks again...
    Bingo!! Took mobo out of case and it came to life. Added hardware one by one and tested to see if still had power. Problem occurred again once front USB was connected. Big help Smithbrother, thanks again!
    President:
  • 2,692 Answers
Seems reasonable. Take the motherboard out of the case,  first to see if it will work outside of the case. Sometimes boards short to the ground due to a screw or other metal getting between them and the case. Try to run it with as little hardware hooked up as possible. You don't even need a hard drive to post the BIOS.
Posted on Mar 12, 2009
  • Thomas F. Schneider Mar 13, 2009
    You are welcome . Than you for the rating. I am glad that it worked out.
Laptop wont boot up
it sounds like the flexcable of your laptop lcd are not working.. so go to nearest pc store and try to replace it..
Aug 13, 2012 | Compaq Presario Computers & Internet
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
I have had my ampeg svt 6 pro for a few years, never any problems until now. I just had a tone pot replaced. Now when i turn it on the fan is blowing at the max and the power light does not turn on and it...
first about the pop noise it caused by the Board inside the AMPEG need to be welding
second the power light simply check the 5v in your power supply
Jul 27, 2011 | Ampeg Svt 6 Pro Amplifier
I press my power button and the fan starts for a second and blue disk drive light flashes like it is loading but nothing comes up on the screen and it will shut off about -5 seconds after pressing the...
have a look on the bottom of the case for access panels, remove these and check the fans for dust build up, even if the dust doesn't look too bad, its worth cleaning. Also try to remove the fan to check between that and the heatsink, dust can build up there very much. This could cause the fan to be innefficient so could be an overheating problem causing your shutdown.
May 06, 2011 | Dell Vostro 2510 Laptop
Power light on, but not responding
just wait till the battery power gets full.
Sep 24, 2009 | Computers & Internet
Very soft ticking noise from the power supply fan
There may be some build up on the fan blades that the compressed air could not free. try using a Q-tip to clean anything stuck on the blades.
Aug 24, 2009 | Computers & Internet
ATX power on Motherboard not working
Just to check the voltages coming from the psu. However if your old psu is doing the same it must be something else. Did you try it without the graphics card? and is it the fan in teh psu which is spinning up?
My next port of call would be any other expansion cards, followed by the memory modules. Take them all out apart from one memory module and try to boot.
Also check that the pins from the power button are connected correctly. you can also try starting the pc by touching the two pins together with a metal tipped screw driver.
Dec 16, 2008 | Gateway GT5032 (827103078121) PC Desktop
Red power light on, making a noise but won't switch on/off
hi dear customer. add fast check the electric power and voltage. latter , cheking jumper on the main board, total main boart opening the cacing out,servising total main board.
Jan 14, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
Computers & Internet Logo
199 people viewed this question
Top Okia Computers & Internet Experts
David Payne
David Payne
Are you an Okia Computer and Internet Expert? Answer questions, earn points and help others
