Question about Refrigerators
Hi. I have a Samsung fridge freezer, model srl3616b. Power is on. Green light flashing on number 3. Fridge & freezer not cooling or freezing. Please help.
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
  • 833 Answers
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Posted on Nov 12, 2008
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Posted on Feb 24, 2009
  • 85 Answers
SOURCE: Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Posted on Jun 17, 2009
  • 340 Answers
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Model number mfd256hew maytag refrigerator not cooling but lights on
HI,
1-Power off for 3 hrs. then again switch on and let it be completely cold.
2-Put away from wall.
Nov 20, 2011 | Refrigerators
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Jun 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
