Question about Kyocera FS-1035MFP
Machine failure call service C6400 KYOCERA 1035
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
bolinlamar
  • 157 Answers
SOURCE: my machine still shows the same: call service
A C6400 Error code can be caused by several different things:(1) A poor connection between connector YC-7 on Engine Printed wiring board and connector YC-2 on Power Supply PWB (2) Defective Power Supply PWB (3) Defective Engine PWB
Note: If you are not a trained Copier Technician you might want to let an expert handle this one. Because this will involve some dis-assembly of the machine and if you are not sure of how to remove the covers and check the electronics, you could cause further damage to the machine and possible injury to your self.
Posted on Sep 21, 2009
SOURCE: I have Kyocera km-2050 it
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Posted on Dec 06, 2010
  • 525 Answers
SOURCE: my kyocera km1820 displays error code c6400
Zero-crossing signal problem
• The engine PWB does not detect the
zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes:
- Poor contact in the connector terminals.
- Defective power supply PWB.
- Defective engine PWB.
Check procedures/corrective measures:
- Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
- Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
- Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Posted on Feb 21, 2011
shawn38
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
How to reset a call c6400?
something to do with the printer not recognizing the power is on
and plugged in to the printer
could try
unplug the ac from the wall ..start again
if no better problem is internal ..call for service technician
Jun 15, 2016 | Kyocera Mita KM-1650 All-In-One Printer
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
My kyocera FS1118 MFP displays C6400 error. Can you help me?
C6400 indicates that the engine board is not recieving the correct signal.
I would suggest that you turn off the machine and ensure that the cable that runs from the document feeder at the top rear of the machine into the connector on the rear of the machine (if fitted) is securly tightened.
You can also try turning the machine off at the wall for 10 minutes.
If this fails you will need to call out a technician.
Jul 21, 2011 | Kyocera FS-1118MFP Laser Printer
My kyocera taskalfa 180 showing c6400 error please help.
To reset -
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
I have Kyocera km-2050 it coming error for call for services error code -C6400
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
My machine still shows the same: call service person c6400. Kindly help me please.
You will have to call a Copystar or Kyocera technician to reset your fuser memory.
Aug 31, 2009 | Kyocera Copystar CS-1820 Black and White...
Call service c6400
it is the problem fuser unite heater lamp or thermostater
Jul 14, 2009 | Kyocera FS-1118MFP Laser Printer
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Problem of kyocera
you probably got hit by a surge... try the best solution on this page...
May 25, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera FS-1035MFP Logo
1,075 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
