Question about Sharp AR-5320 Black and White Copier
Brother MFC has a horizontal white line. What is the problem? new drum installed and fresh toner.
  • 62 Answers
(1) Check the paper used meets the recommended paper specifications. A rough
surfaced paper, damp paper or thick media can cause the problem.
(2) Check that the appropriate media type is selected in the printer driver.
(3) The problem may disappear by itself. Try printing multiple pages to clear this
problem especially if the machine has not been used for a long time.
(4) The drum unit may be damaged. Install a new drum unit.
Posted on Mar 13, 2009
Black lines when printing brother 9320cw
Vertical black lines means the printer requires maintenance or a new drum. Horizontal lines means a circuit board with problems.
I do recommend maintenance every 6 months at least.
I hope this helps.
Nov 23, 2010 | Brother MFC9320CW All-In-One Printer
Laser printer horizontal streaks go away after a few pages
The operating principles behind laser printers are fairly simple. In fact, Brother machines more closely resemble large copiers than conventional laser printers, this is why they are so reliable.
There are a couple of things to look at:
On the drum unit: is the imaging drum worn or scratched? When did you last clean the corona wire?
If the drum is scratched or otherwise with defect it should be replaced. If the corona wire is dirty it can fail to properly charge the drum and lead to print defects.
On the toner cartridge: Does the toner roller have any noticeable lines or banding in the toner?
Behind the toner roller is a "Doctor Blade" that ensures an even and consistent coating of toner. If there are lines in it they can produce print defects as well. Lines would be likely caused by toner accumulation on that blade. If there are lines, are you are careful, you may be able to clean the blade by gently and slowly scrubbing the non adhesive end of a post-it note between the toner roller and the doctor blade where the lines are.
Jan 15, 2010 | Brother HL-2070N Laser Printer
How to take out brother tn 330 toner, mfc-7340
You open the front door and pull out the drum and toner assembly and then press the blue lever to release the toner from the drum, place the new toner in the holder and install both together into the machine.
Nov 19, 2009 | Brother MFC-5840CN All-In-One InkJet...
My Brother mfc 4800 after changing the drum and toner prints so light that it is almost unusable
Return both and get a fresh batch. You could have gotten a bad drum or toner. But first take out the toner and get her a good shake just to loosen it up if there are any clumps or jams
Aug 07, 2009 | Brother MFC 4800 All-In-One Laser Printer
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
I have horizontal white lines (non print lines)
Slide the small blue tab on the toner cartridge side to side 10 times.
Jan 22, 2009 | Brother MFC 8500 All-In-One Laser Printer
Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
May 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 9700
Remove your drum unit and you will see on top of where the drum unit sits inside your machine is a piece of glass(inside the machine). Wipe the glass with a soft dry cloth. If this do not work, remove your toner cartridge and see if the toner is spread evenly on the cartridge.
Mar 17, 2008 | Brother MFC 9700 All-In-One Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother MFC-8500 prints solid gray pages
I have seen the Toner cartridge in these cause this and also thought it was drum but new toner actually fixes it, have you installed new gen toner as well as drum? Make sure you tell machine you have fitted new drum too,
Sep 08, 2007 | Brother MFC 8500 All-In-One Laser Printer
Sharp AR-5320 Black and White Copier Logo
75 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
