Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Activate USBs on monitor
Where can I purchase the cable I need to connect the monitor to the hard drive to get the two usb ports on the side of the monitor to work? They did not have one at Staples or Radio Shack.
    Scholar:
  • 77 Answers
USB slots on a monitor act as a USB hub, and thus need a USB cable to connect from the monitor to the computer. Check the plug type on the monitor, if will either look likea normal USB plug in near the power and video cables or it might look a little more square; simply get a USB cable of this type (Type A for normal, type B for squarish) to connect from your monitor to a normal USB plug on your computer ( Normal being type A), and it should work.
Posted on Mar 12, 2009
  • WebKill Mar 12, 2009
    One additional note, most electronic stores have these cables, BestBuy, Radio Shack, even Target and Walmart. You can also get them online:
    A to B Cable:http://www.usbgear.com/340823.html
    A to A Cable:http://www.usbgear.com/317887.html
Beeping and not detected external hard
Beeping usually happens when the harddisk does not get enough power.
Try 2 things: 1. a smaller cable, 2. USB port at the back panel on a PC.
Front panel USBs are shared, also try removing everything connected to front USB ports.
Mar 29, 2016 | Hard Computers & Internet
How do i use it?????
This hard drive come with a cable. The cable is a USB Cable Its simple to use!
Connect the hard drive to USB Cable and other end connect to your computer's USB port.
If you have Laptop computer these USB ports are on the side or back of the computer and if you have desktop computer the USB ports are mainly in the back!
Sep 08, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
Can it be used as external hdd
Yes it can be used as an external hdd.
This is the only procedure i know and i hope you'll be satisfied.
Things You'll Need
Screwdriver
Locate and purchase an IDE to USB cable conversion kit. Insert the driver CD that came with the kit into your computer's CD drive. Follow the instructions on the installation prompt that will appear on your computer's screen to install the conversion cable driver software.
Power off the computer once the driver software has finished installing. Remove the power cable and all of the other cords from their ports on the back side of the computer.
Set the entire computer case on its side so that the left side panel is facing upwards. Check the back end of the case to determine if the side panel is locked with two case screws or only a metal latch. Disconnect the panel from the case either by removing the screws or by pulling upwards on the latch.
An IDE Cable
Pull the side panel off of the computer case and set it aside. Locate the drive that you want to connect with a USB cable. Remove the screws holding the drive into the drive bay. Disconnect one end of the IDE cable from the motherboard, but leave the other end connected to the back side of the drive itself.
5
Remove the drive from the drive bay with its connected IDE cable and set it outside of the computer case. Set the side panel back onto the case and re-attach the metal latch or case screws. Plug the cables back into the computer ports and power the computer back on.
6
Insert the end of the IDE cable that used to be connected to the motherboard into the IDE port on the conversion cable. Plug the male USB end at the other side of the conversion cable into any open USB port on your computer.
Have a nice day friend and i hope this would satisfy your needs.
Aug 20, 2011 | Samsung (SP0411N) 40 GB Hard Drive
After connecting usbs, maxtor drive does not show up on pc screen. Therefore cannot see any files at all !!!! declan
Make sure you are connecting to a usb port directly on your pc and not through a usb hub. If that does not work try another usb port on the back of your pc. Also make sure the power supply to the hard drive is working. If that fails try looking for the drive in "My Computer or Computer" and if not there check in "disk management". Also try disconnecting all other usb devices except your keyboard and mouse reboot and then try connecting the maxtor drive.
Thanks for using FixYa
Jul 04, 2011 | Maxtor Computers & Internet
SATA hard drive not recongised.
hi, sorry but i have to ask the question , why did you take the drive out of a external drive then buy a kit so as you can use it as an external drive , if its because the Seagate casing is damaged then its highly likely the drive is damaged too .
Apr 28, 2010 | Seagate 1 TB SATA II Hard Drive
Icon won't appear on desktop.
It is possible that your USB flash drive is dead.
The other solution is to try it on some other USB port of your PC (if you used front panel USB ports now try it on the back panel).
If it also wont work, try to connect it to some other PC
If it works with an other PC, your USB ports are dead
You can try going to device manager, and to unintall USBs and reinstalling them
Nov 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Laptop does not recognize my Drive Station, External USB 2.0 Hard Drive, maker: Buffalo worked fine for months now nothing.
I will help you diagnose.
Lets check the easy stuff first.
1. First- Just switch to a different usb port.
Try?
2. Try using a different cable.
Try?
3. go to my computer, properties, hardware, devices, scroll down- delete usbs-
unplug your harddrive from your computer -after having turned it off of course.
leave off for eight seconds
Plug hard drive back in
Try?
4. Try restore computer to a time the Hard Drive Worked?
Try?
Diagnosis Crashed Drive
Mar 26, 2009 | Computers & Internet
I can't use the USBs from my HP monitor
there is a usb port on the monitor that will run a cable to your computer this needs to be plugged in square plug to the computers rectangle one.
hope this helps
Mar 22, 2009 | HP w2207 Monitor
I'm sorry my enlish verry littl. Mi HDD Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive No runing. I chenj cabl
Hi. Is the power light on the drive on? Is it flashing (this indicates an error)? If it is check the usb port you are using. You cannot use a usb hub, a usb port on a monitor or any other port that is not directly connected to the computers power supply. If you are using a dock make sure that both of the plugs are connected to powered usb ports. I could not get this drive to run until I plugged it into the right port. Use only the short cable that comes with the drive or the dock that is made to use with the drive. I hope this suggestion helps.
Jan 15, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I recently purchased an external hard drive, and how do connect it to my computer.
External Hard Drive is mostly of the USB interfacing type. If urs one is the same, then it is just as simple as plugging in a pen drive in the USB port. If it has external power supplies then u can easily figure out how to connect. There are two parts in the power supply (if external power supply cable is provided), 3-pin main power supply connector and other is the adapter which goes to the external hard drive.plug in the other end of the adapter into the hard drive (there is a hole in it). connect the main power cable to the adapter extension. now for the usb Hard Drive, connect the USB cable to the USB port of the computer. Switch on the power supply to the Hard drive and u r ready to use ur brand new External Hard Drive. If it is a Firewire interfacing one then u may need to open the CPU box, and then connect the firewire connector on to the motherboard firewire port. It is easy to identify, it is a red colored port/connector.
Oct 11, 2008 | Western Digital 500GB My Book World...
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
149 people viewed this question
Alun Cox
