Error code EC on my split type kolin inverter aircondition unit
I hope someone could help me solve this.
  • 1 more comment
  • jamal
    jamal Jun 11, 2016
    not satisfactory
  • John rey onofre Oct 12, 2017
    What the problem of EC error for fcu.wht is the trouble error
  • Bernard capanay Nov 22, 2017
    wat es the meaning of p10 error cod of kolin ac
E6 codes
Posted on May 20, 2014
  • 3422 Answers
SOURCE: ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
The first thing i'll say is you will need to get it repaired by a technician and i strongly recommend you not to do it by urself.
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit.
Goodluck..
Posted on Mar 22, 2008
SOURCE: my carrier split type non-inverter aircon always blinking
I got the same problem in Samsung aircon. The unit I purchsed died slowly. After that Samsung replaced it with the one have the same problem. They are swearing that the green light blinking problem as a normal function and refusing to fix. Their user manual says it is a problem. I think the affected consumers should join hands to take legal action against this scam.
Posted on Dec 20, 2011
hvac1960
  • 2133 Answers
SOURCE: Hi my LG healthplus inverter
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor
Posted on Jan 20, 2011
hvac1960
  • 2133 Answers
SOURCE: Split unit airconditioning DSA099L. Trips
F-6=High discharge temp/overheating compressor.
Due to condenser block (Clean it),/less RPM of fan motor (Replace capacitor)/Noncondensable gas( Remove gas flush out system, vacuum and do gas charging..
Helpful?
Posted on Jan 02, 2011
hvac1960
  • 2133 Answers
SOURCE: the led panel on the
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Posted on Dec 16, 2010
Kolin error code E1 inverter 1hp wall mounted
What do you need to know, how to fix the error? If you need more questions for your AC Repair needs, check us out online.
Jul 12, 2017 | Inverter Heating & Cooling
E1 error code kolin inverter
Do want to know what the error means? Do you want to know how to fix it? If you need more questions for your Air Conditioning Repair needs, check us out online.
Hi, when i turned on my Senville mini split the fan will go on for 2 - 3 minutes and then the air conditioner will display P4. On the error code description, it say inverter compressor drive error.
contact the manufacturer to see if they can help you with this type of failure. the compressor and its controller are the two most expensive parts of the unit to repair.
Jul 29, 2016 | Inverter Heating & Cooling
Es error code kolin split type
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
For more information on AC Repair Tamarac Check us out.
Apr 19, 2016 | Heating & Cooling
Streamline. What does error E0 mean?
How to fault find a Daikin Air Conditioner, troubleshoot split ...
? 4:22
www.youtube.com/watch?v=i30rEvyuDKs
Feb 10, 2012 - Uploaded by Fully Airconditioned This video shows how to get fault code from remote control and reset fault, you ... Daikin Inverter AC Unit Fail - Moisture / Salts Damage to PCB ...
Sep 30, 2015 | Inverter Heating & Cooling
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
What do you mean by EC?
i do not know if i got it correctly but it seems that there is a code after this right? it Error Code..
Jun 17, 2014 | Heating & Cooling
My LCD screen went of but there still sounds coming out
you have to check the back light off your lcd replace the inverter or capacitor in the power module
Jul 16, 2009 | Olevia Kolin DLT2711M 27 in. LCD...
Heating & Cooling Logo
6,981 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
