My laptop Compac NX 7400 doesn't run when I connect it on AC sector with the battery removed. Even with battery nothing comes. What the problem ?
    New Friend:
  • 10 Answers
That sounds like you may need a new AC adapter. If you need help finding the right AC adapter, I can help you.
Posted on Apr 23, 2013
SOURCE: Dead laptop
where is reset button
Posted on Jan 18, 2008
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
Geekman
  • 32281 Answers
SOURCE: compag nx 7400 my laptop power supply not work
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 07, 2011
SOURCE: Mine is dell latitude d620
my dell laptop doenot want to turn on even though it gives the green light
Posted on Nov 09, 2011
kd_sargent
SOURCE: I have an acer aspire
Bottom Line the manual says if the light to not come on when cord is bluged in battery out get a new motherboard. You may also hear a slight ticking like a clock tick.. The Issue is the U58 chip on bottom side of motherboard burns out. sometimes takes out U63, U59 and U64 are same corresponding chip and can fail as well at worst case... Usually just U58..it is a 4812 chip you can get for a few cents...I heard how ever if you replace U58 and think U59 with the U63 chip a 4800IC chip the issue goes away... Trying to confirm... Until I confirm recomend either new mother board or correct U58 chips 4812..mosfet n channel..
Posted on Aug 26, 2012
When i plug the charger in the orange battery light comes on and the computer turns off
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Sep 29, 2012 | Toshiba Satellite P200D-11R Laptop AC...
Cant ge my hp tablet to turn on
If it doesn't anything at all, not a indicator light nothing, it is likely the battery is the problem and will need replacing. Make sure the charger is good first. If the battery is completely open it will not run even with the AC cord connected.
Jun 08, 2012 | HP Computers & Internet
There's seems to be a short where the AC adapter goes into the Laptop. Loose parts in that area of the Laptop where the adapter goes in. It won't turn on. Maybe it's the battery.
Unfortunately, this is a frequent issue with laptops. Being moved around frequently can cause the AC Adapter to pull at the DC Jack on the laptop. If it is loose, it can mean there is a broken connection within the laptop. What you can try is powering the laptop on with it plugged in and the battery removed. If that doesn't work, I'd recommend going to your local Best Buy and picking up a universal AC Adapter. If that doesn't work, you can always return it, even if opened.
Aug 27, 2011 | Acer Aspire 5735 Notebook
Nc6000 when ac disconnected, computer shuts down even though battery charged 100%
Hello, if on XP, go to control panel and open up 'Power Options' and look to increasing the 'Running on batteries' settings. However, you don't say whether it will power up without the mains connected...if it doesn't then maybe you've a bad/poor battery connection, ie it will display a voltage to the monitoring system, but won't allow any current to be drawn....this could be due to a bad connection so it may be worth removing the battery, taking a look at the connectors (maybe wipe them clean) and then refit and try again. Best of luck Nicam49
Jul 27, 2011 | HP Compaq nc6000 Notebook
Acer extensa 4620 z will not power on have a new ac adapter and power cord . i can charge battery and charge battery light comes on but push power button and nothing
Try the following, one at a time.
- Remove battery then connect power cord, then power on
- Remove the memory modules then power on
- Remove the other optical drives, then power on
- Remove other components, then power on.
This process is to illiminate the faulty component. It is possible that one component is faulty and is causing shortage that's why your laptop won't power.
If this doesn't work then you need to remove the internal components like hdd.
Hope it helps.
May 08, 2011 | Acer Computers & Internet
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
Laptop won't power up
if there a battery, try to remove the battery and put the charger..try to check if the power come or not come.
second, if not come the power without battery..you must check first the charger output,working or not working..and third, check the power jack...thats the last...
Jan 04, 2009 | Compaq Presario Notebook
Compaq Armada 7400 AC Adaptor Pins
Below is the URL for compaq's Service Manual for that model. This shows you the details of every single part & how to disassemble and reassemble every screw. Surely it has to be in this document, somewhere. --> ftp://ftp.compaq.com/pub/supportinformation/forum/portables/7400msg.pdf
Aug 04, 2007 | Compaq Armada 7400 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
