My uniplan e machine gives me an error L1 screen
My uniplan e machine gives me an error L1 screen display after the air blower turns faster and stops within some few seconds. Please help me fix the problem.
TVtechmaniac
  • 140 Answers
SOURCE: air flow error
There is a Mitsubishi service bulletin for this problem.The source of the problem is the connector to the thermal fuse by the lamp. The fix is to cut the connectors off and hard wire the fuse (you will have to splice in a 3"inch wire extension to make it reach once the 2-wire connector is cut off)
Posted on Aug 30, 2007
SOURCE: LCD Tv turns off automatically within few seconds
It is a software problem sony was fixing for free untill 03/01/08
You can unplug your set from the outlet for 30 seconds and it will work fine untill several hours of use acrue again. Found this out on the sony website. hope it helps.
Posted on Mar 11, 2008
  • 101 Answers
SOURCE: washer only responds for a few seconds ,does not display any error code, it only allow water in for a few seconds, if you select spin only , it turns the pump on for just a few seconds
May be it more or less the timer points are bad at that part, most likely you have change the timer.
Posted on May 12, 2008
SOURCE: System Error L1-00
Most of the time the scanner is locked. There is a clear plastic lock located under the scanner. Look on th e top in the opening where the paper comes out, one way locks the scanner for transport the other unlocks it for use...
Posted on May 26, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint wt965 f04 error
F04 indicates that the pressure switch is jammed on empty,
check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an enginner
This really is your only option.
Plz rate my solution
Thanks.
Posted on Dec 18, 2008
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Nordic Track C2200 Error Code 440-17E what might be wrong?
reset the machine, follow this step and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 21, 2013 | Exercise & Fitness
Boiler ignition is loud, boiler runs for a few seconds then goes out
flame sensor, air flow restriction or blower not producing enough pressure. clean the flame sensor to start. inspect venting, etc
May 13, 2013 | Jandy Lx Pool & Spa Heater - Electronic...
I have a dodge grand caravan 1999 with 319k miles. ac issues
I think your blower motor resistor is bad. The link is a YouTube video showing the location and how to replace this resistor.
Replace Blower Resistor for 2000 Chrysler Town and Country
Jun 04, 2017 | 2000 Dodge Caravan
Sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Dryer starts, but stops in a few seconds, display code F 40
The F40 error is a communication error which means the main control W10111616 is not communicating with the motor control part number 8544799.
First - go through the machine and check all harneses 7 plugs. This expensive machine uses the cheapest parts possible. Unplug and re-plug all connections you can find.
Particularly the controller (CCU) and motor.
Most likely neither control is the problem but since the main control was replaced we know it's not the problem.
The key to diagnosing this problem is to check voltage to the motor control. There is a black and white wire going to L1 and neutral.
Refer to the wiring diagram for an image of this.
If there is 120 volts to the control and the blower motor is not running then the 8544799 motor control is most likely at fault.
It is more likely you will not read voltage there.
Use extreme caution checking live voltage and only do so if you're comfortable and confident using a volt/ohm meter.
If there is no voltage to the motor control and the main motor doesn't run the thermal fuse can be at fault or the main control which was replaced and didn't help.
From the description you give I believe the main motor is running when you get the F40 code so the thermal fuse and main control are most likely okay.
If there is no voltage to the motor control then the problem can be a fuse link that may be open preventing voltage from getting to the motor control.
This part is not the thermal fuse and is not listed in the parts diagram or even shown on the wiring diagram. The fuse link is most likely the cause of your troubles.
If the inline fuse link is open you will have to replace the entire wire harness. The inline fuse link is not available as a separate part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Lexmark C500 printer SVC LL ERROR, SVC L1 ERROR
As i'm sure you already know the error means - Laser power is lower than the output limit.
It's probably due to a bad contact on the engine board. If you would like the service manual it can be downloaded from the following link free of charge http://www.eserviceinfo.com/equipment_mfg/Lexmark_22.html any problems come back to me.
Aug 11, 2008 | Lexmark C510n Laser Printer
Washing Machines Logo
441 people viewed this question
Top Washing Machines Experts
