Question about Epson L200 Original Continuous Ink Tank System cis Inkjet Printer And Scanner
How to fix mainboard when can't turn on
    Novelist:
  • 148 Answers
What makes you say that Motherboard needs fixing? If you hear cpu fan working and hard drive turning plus some indicator lights especially one for HDD then Graphics problem most likely, BUT with not clear explanation by you what you mean not you mean not turn on, naturally PC need good working PSU, motherboard to be Ok, Graphics and Memory only to be able to get into BIOS, all other devices can be re-connected later.
Posted on May 03, 2013
Power supply or mainboard?
what is the model # of your TV
Jun 02, 2013 | Televison & Video
Lg 50pg20 blinks red and blue and doesn't turn on
replace your mainboard or power supply board i would try the mainboard first
Jan 30, 2013 | LG 50PG20 50 in. Plasma HDTV
Need large, clear diagram for MSI motherboard, type ms 7613-iona gl8e
Hello this mainboard belongs to the HP/ COMPAQ support:
https://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655
The manual:
https://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&docname=c02014355&lc=en&product=4262655&
You can`t find anything at the msi support site.
Do you get any picture (blue screen of death) ???
Any beep sound ???
This fault could be: ram failure,harddrive,graphic card,cpu.
Or sinply mainboard is dead.
It`s always difficult to do fault finding on a mainboard.
Many thing can go wrong.
And it will sometimes cost more
than a new mainboard or pc to solve the problem.
Ask a qualified repair shop (hp support) about known issues
with this mainboard.
Good luck
Nov 25, 2012 | MSI Computers & Internet
P4b266-c won't turn on
Hello the homepage is here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=15&m=P4B266-C&os=&hashedid=n/a
Please select your windows and download the manual.
The file needs to be unziped.
My guees is that the powersupply is dead.
You can still buy a new one.
But some old asus mainboard has bad capacitors.
Does yours look like this:
If they do it does not pay to let them be changed.
The mainboard is 11 years old and i guees the time has ran out for it.
I whish others could hold that long.
Hope this was helpfull
Nov 15, 2012 | ASUS P4B266-C (P4B266-C WA) Motherboard
Mouse and keyboard not working - how do i boot up computer
you may installed the hardware wrong or your system mainboard suffers from critical problem. if its not so remove the mainboard battery and put it again after 15 minutes it resets your system bios.
Jan 16, 2012 | HP Compaq Business dc7600 PC Desktop
JVC 32", 11 years old. flashes from picture to
after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so in your place contact few TV service engineers & ask them how much they will charge for resoldering joints on mainboard & crt tube's circuit board ......
Sep 05, 2011 | JVC Televison & Video
When we turn the tv on the picture has lines i hit the back of it and the picture comes in
after 4 or 5 yrs ( depending on usage ) in some TVs on mainboard & crt tube's circuit board at few soldering joints cracks develops ...... then due to loose connection TV behaves as you said ..... so solution is most of the soldering joints on mainboard & crt tube's circuit board should be resoldered carefully ....that'all your TV will again works normally ......100% GUARANTEE
Sep 01, 2011 | Mitsubishi CS-35505 35" TV
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective ..........so flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) .............so in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back ....now turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work )......at the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many shops...now turn all the knobs of new flyback in anticlockwise direction very very very slowly until it stops....now fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected ....now connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry ....in the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull ..now while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV ....so now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Aug 31, 2011 | JVC Televison & Video
Sound turns off after tv is started sound only one
Hi my name is Roety,
I can help you with your issue ,
Without a model number, I do work on sony LCDs.
The audio is on the mainboard. You need the mainboard replaced.
Reboot every device by unplugging the AC power , if the sound still cuts off replace the mainboard
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 10, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Epson L200 Original Continuous Ink Tank System cis Inkjet Printer And Scanner Logo
100 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
