Question about Refrigerators
Frigidaire Model #XFUT1826MW1
Just changed the temp to "Colder" and it still remains warm. Its less than 6 months old and I've already cheched the vents. HELP!
HVACRH20
  • 237 Answers
SOURCE: Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Posted on Dec 20, 2006
22yooper
  • 828 Answers
SOURCE: freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
Posted on May 22, 2008
EllaWatson25
  • 725 Answers
SOURCE: 1 month old Frigidaire model # FRT21IL6JM2 has not
Are you still under warranty? Call the place that sold it to you and ask them for a loaner until this one is repaired or replaced. Most honest places will provide one for you. Hope this answers your question and the best of luck to you, too. Ella
Posted on Aug 26, 2009
heatman101
  • 43501 Answers
SOURCE: My Frigidaire Professional series refrigerator
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 08, 2010
heatman101
  • 43501 Answers
SOURCE: I need to make the refrigerator warmer. It has an
Turn it to a lower number to make it warmer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Dec 27, 2010
I have a 2005 dodge durango that's over heating.
The basic answer is not enough coolant flow or not enough air flow thru the radiator. You'll have to find out if the coolant is flowing when the thermostat is open, is the system full of fluid, and is there enough air flow thru the radiator.
Does it get over 220 degrees if you are moving and at idle too ?
Jun 17, 2013 | Cars & Trucks
The "F" LED remains on and I'm unable to get it to change states by depressing the settings button. This has happened on two of the units that are both less than 6 months old. Any ideas?
Copy following link to identify timer, and find comparable product that might last longer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Check output voltage at outlet using multimeter. Should be minimum 80% rated value or 110Volt outlet = 88 volts
Check outlet with circuit analyzer for correct polarity and grounding.
All timers come with 1 year limited warranty, in this case it will be through seller because first alert does not show timers on their website.
Don't buy First Alert products.
They are generally cheaply made promotional grade timers.
I recommend Intermatic HB61RC or Woods 49103 or Intermatic HB65R because their products are good, and warranty policy is direct from company.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 24, 2012 | First Alert Hardware & Accessories
Washer has squealing sound and burning rubber odor
Yes, its basically in need of a overhaul, which the parts involved, basket drive/clutch and gearcase are all wearing out, I've seen this happen many times and cause the squeal/spin cycle and then in time to slow then stop spinning altogether.
From the parts diagram it said this model was made in 1998. The only time I have changed these parts on a model this old is when the customer purchased a service contract when it was new and kept paying on the contact year after year, thus the repair was free to them, but most of the time its NOT practical to keep paying on a service contact for up to 10 years unless you have heavy/extreme, daily/many times of day use of the washer, usually for large families living in the same household.
Here's the list of parts I always change for this issue, now some members and techs. could possibly change just the basket drive/clutch assembly or just the clutch alone and it may work for another 6 months or year and a half, but I found when I used to change the parts separately I had to go back to change the other parts within 6-18 months.
Oct 14, 2012 | Frigidaire GLWS1349A Top Load Washer
Amana refrigerator with freezer on bottom frosts up on rear vents in freezer resulting in the inability of the refrigerator to remain cool. A hair blow dryer can usually melt the frost on the freezer...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 11, 2011 | Amana Refrigerators
We can put in the minutes and temp., then when we close the door the clock times down and the fan blows, but nothing cooks. Fridgidaire model cfmv156fmc. For a while if we put a piece of cardboard in by...
I threw mine away because frigidaire would not do anything for it and was less than 6 months old . local dealer would not look at it as we bought from a big box store not them .
Dec 09, 2017 | Frigidaire Microwave Microwave Oven
Hello, we are having some trouble with our Frigidaire dehumidifier model FDR30S1. It runs but is not pulling in any moisture. We've tried a few solutions but have not been successful thus far. What is...
Generally, most humidifiers work best between 60 -80 degrees . There is a model that is called a Low Temp model, that's designed for low temperatures in basements.
As far as your problem is concerned, there are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, set the Manual Control Knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 27, 2011 | Frigidaire FDR30S1 Dehumidifier
Using 1 quart a mth. no visible leakage. i can tell when it starts getting low by how it runs. live in mx. 110 /87% humidity. is this normal usage? i never had to put in extra oil and get it changed every...
One quart per month is a bit more than I'd expect but you didn't mention how many miles you drive during that month.If you live where the ambient temps are very warm, it may help to use a good synthetic. Synthetic oils do not burn off or break down chemically as fast as conventional oils do. I'd use a 20w40 grade.
Depending on the miles you've driven you shouldn't have excessive ring wear but the valve stem seals may have dried out and cracked. If the usage remains constant and there is no smoking etc, you could either leave it alone or have new seals installed.
Average driving is approximately 1,000 miles per month so when figuring consumption, use that as a baseline. One quart per 1,000 miles in very hot conditions is a bit high....I'd expect to see 1/2 qt or slightly less. One odd thing though is that generally, especially in an engine that holds six quarts to begin with, at five quarts, the engine should not feel any different!!!
Also.....you use miles to determine oil change intervals. Oil is best changed at between 3K and 4K miles. Only way you use the 3month method is if you don't use it much. (you can run most good synthetics longer than that)
Jul 14, 2011 | 2002 Jeep Liberty
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    Everthing works ok just the temp.is to cold
    should be a thermostat somewhere on the unit. Might be called 'temperature control,' or might just say 'colder' in one direction and 'warmer' in the other.
    You just need to 'dial back' the temp controller in order to 'warm it up a little.'
    good luck!
    Jun 14, 2011 | Heating & Cooling
    The temperature in our refrigerator (Whirlpool Gold GD22DF) is not low enough this morning. Things don't feel cold. I've moved everything to a cooler and removed a small block of ice in the vent...
    possibly the air damper motor has failed and needs tech help . you can possibly get by blocking the air damper open slightly but permanent fix needs done
    Oct 08, 2017 | Refrigerators
    Refrigerators Logo
    63 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
