Unable to reboot
My computer keeps turning on and off so that I can't reboot with my xp cd. It keeps showing that my computer shut down due to power failure, etc and it shows that I can restart using normal mode, safe mode, etc, but when I highlight them and hit ener---computer shus down and turn back on and keeps recycling on/off
  • Serbob May 11, 2010
    You've probably got a hardware failure somewhere. I'd try removing a stick of RAM and see if that helps first. From there it could be power supply, hard drive or mother board.
    Can you get to the BIOS? If so, you can do a memory check.
  • 67 Answers
Sounds to me like you have a bad or dying power supply. Try finding a friend with a working power supply and hook it up to your computer, if the problem ceases, then go get yourself a new power supply. If the problem persists, it may be an issue with cables or the fuse, maybe even a bad motherboard.
Posted on Mar 12, 2009
Coby Electronics Corporation Coby Kyros MID9042-8 9" 8 GB Tablet Computer - keep shutting down
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 23, 2013 | Tablets & eReaders
My coby kyros mid9742 will not start up at all it just keeps rebooting
Apr 19, 2013 | Coby Kyros 716829701508 Tablet PC
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
Laptop not show cd or dvd when i put it
Well, for starters, is your cd/dvd turned on in the bios.  Some but not all computer have a setting for this.  If your cd/dvd drive is removable, shut down the computer, remove the drive.  Reboot the computer and shut it down again.  Then reconnect the drive and start the computer back up.  This will make sure that if your drive is working, windows will redetect it.  You can check device manager to make sure it is not disabled.  If none of this works, you may have a bad drive.  If you really must reinstall windows, you can get an external cd/dvd drive pretty cheap on Ebay.  Just make sure you go into your BIOS setting and change the boot menu to external drive.  I hope this information helps.
May 30, 2009 | HP Compaq Presario C700T
Formatting C Drive and Re-Installing Windows XP - BSOD
just take a backup c drive and profile documents
and format the c drive and install the operating sysytem
Apr 16, 2009 | Compaq Computers & Internet
Remote access to dial-up connected computer
https://secure.logmein.com/home.asp?lang=en
Try this.Set it like after reboot it automatically starts.
Once it comes up you will be able to connect again.
Please rate me if you like my solution.
Mar 12, 2009 | Microsoft Windows XP Professional Upgrade...
Shuts self off during start up
Sounds like there could be a major problem with the hard drive.
Have you got an XP or Vista cd? NOT a restore cd.
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Windows xp pro
Did you reinstall windows, or install another operating system? Have you placed your windows disks in your computer recently? To add files or possibly drivers?
This is in your ROOT boot up .ini file, which shows that loading screen, also there is an option that has blocked shutting down your computer. I can help you get to shutdown, is this a laptop, is this a home computer? Did you recently place this unit in the shop. All of these answers do matter for me to give you assistance.
ManOwar
Aug 07, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
