I have a hole in my seal and it is leaking out the door can i buy a new seal or do i have to replace the washing machine
  • boris1804 May 11, 2010
    you can purchase a new seal for about £35.00
    to fit it can be a bit fiddly
    what model number is it ??
  • steve
    steve May 11, 2010
    New seals are available at your local appliance parts store.
  • 27 Answers
You can replace the seal
most appliance spares centres will sell boot gaskets
Posted on Mar 12, 2009
Fitting new door seal ,how to remove old seal and fit new seal?
Follow these steps to replace your door seal:
For all Free appliance repair videos visit ourVIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a springsystem holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in ourtutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Mar 31, 2010 | Hotpoint Aquarius WD640 Front Load...
Duet GHW9100LW1 the machine is leaking and not draining property what do i need and where can i find these parts
depending where the leak is,in the rear it could be the wash tub seal in which you need new seals and while its out replace the bearings,if its in the front,then either your door boot seal is torn or the drain "weep" hole is plugged by soap scum and mildew
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Seal on door leaking---where do we get a new seal?
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Jan 03, 2010 | LG WD-1080FD Front Load Washer
Fitting a door seal to a Zanussi ZWD 1270SA washing/drier
For all Free appliance repair videos visit our VIDEO TUTORIALS
Dec 28, 2009 | Zanussi ZWF1440 Front Load Washer
I have a hole in the grey rubber seal that connects between the drum and the front. water leaks through and down the inside front panel of the machine. Can i buy a replacement part? How hard is it to...
You can buy a new door seal.
It is a fairly tricky job to do it your self.
To get some one to fit it, I would expect you tp be paying around £70.00 to £90.00 depending on who you get, so get some quotes.
Hope this helps.
Dec 02, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Need to replace door seal hotpoint aquarius wf220p door seal ...help please
Nov 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
I NEED TO KNOW WEAR TO BUY A NEW DOOR SEAL FOR A HEC washer
Aug 08, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Replacing door seal
Sep 15, 2008 | Zanussi FLE1416W Front Load Washer
WASHING MACHINE DOOR SEAL REPLACEMENT
Sep 17, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
244 people viewed this question
Top Washing Machines Experts
