Question about Cell Phones
Enter pin code of brivis heating module
My ducted heating system didn't work. I rang Brivis service then charged 25 Dollars for technical servis but I couldn't fix. Technician from brivis came and chekced system he recomonded to replace system but this one fiarly new (4 1/2 years old). When check the heater module & press the button appeared 'enter pin'. After get advise from technician's advise I entered pin code 1111 but didn't work. Now when power connected display "SECUERD" on heater module screen. Enyone can help to solve this fault, meny thanks.
dapidc
  • 111 Answers
SOURCE: I've tired to set the PIN code for my Nokia 6085 phone but I cannot.
HOLD ON!
You may enter wrong PIN three (3) times only. After that your PIN will be blocked! To unblock, you need PUK. You can only enter wrong PUK ten (10) times. (This is as documented) After entering correct PUK, you will be asked for NEW PIN.
So, when it says "PIN blocked. Enter PUK code", you must enter the PUK. If you correctly enter the PUK, it will asked for new PIN, by asking "Enter new PIN code:". Enter anything you want as your PIN. You will be asked to enter it twice (two times).
From what I read from your post, you have done correctly, but you don't want to enter new PIN. There is no way SIM card/phone will use old PIN. The device doesn't know your PIN. So, you have to enter new PIN.
Posted on Dec 25, 2008
  • 173 Answers
SOURCE: Puk code
PUK code can only provided from your service provider/carrier. Call them and ask them for your PUK code and enter that into your phone. then it will accept your NEW 4 digit PIN number. Do not enter any more random codes as it will permanently deactivate your SIM card and then you need to buy a new one.
Posted on Mar 19, 2009
270rexton
  • 782 Answers
SOURCE: My sim card is blocked on my Blackberry 8830
PUK code can be used 10 times,then SIM card is gone forever. PUK is needed if 3 times wrong PIN was typed. So type PUK and when ask New PIN choose any number (4 digits) then re-enter again and that's it.
Posted on Sep 20, 2009
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
SOURCE: enter PUK code, asked for new PIN code, but then get "code error"
enter new pincode code error
Cost of Brivis Manual Controller Part No BO22880
$50 AUS on ebay
Brivis Thermostat eBay
Otherwise, call customer service at Brivis. They handle spare parts. For some reason, I cannot find the part at their site by serial number.
Jan 27, 2018 | Heating & Cooling
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Cannot start the Brivis heating device
I have been without heating for the past month since the fan motor in my ducted gas brivis heater filled the house with smoke.
The guy replaced the fan motor, and then it had the same symptoms as yours.
After a month of various tradesman trying to work it out, it has come down to the "thermal switch" within the unit.
Jul 29, 2008 | Heating & Cooling
Brivis Ducted Heating system. No display on Programmable controller inside hoiuse. Electronic Control (Model 14100) located on Heater (outside house)displays "Searching". Have turned off...
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Cheers
James
Jun 10, 2008 | Heating & Cooling
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
