Question about HP Audio Players & Recorders
Im using a Non USB headest, it has power, but no sound.
I was using a USB set, it died on me a few days ago, i went and bought a set that plugs directly into my sound card. Its receiving power, but is not putting out sounds.
I have tried an old set of Speakers as well that work on the same set-up, Orange mark goes in orange hole, green in green and so-on. both have no sound, but power.
  • hackjob101 Mar 12, 2009
    i've updated, or been told by my system that there are no better updates, my drivers already, still got no sound
  • 66 Answers
Download and install the sound drivers for your audio. Go to your manufacturers website and get it.
Posted on Mar 12, 2009
  • Atticus30
    Atticus30 Mar 12, 2009
    try a different usb port
89 camaro starts wont crank when it does wont idle and dies after 3000 rpm when you hold accelerator
Could be a problem with the pickup coil in the bottom of the distributor if equipped. The pickup coil provides the crank signal for the injectors and ignition module.
Did you clear the code and then 53 came back ?
On most models code 53 means the computer or one of the components is getting over 13 volts.
Sep 11, 2012 | 1989 Chevrolet Camaro
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
I have a ka08 cell phone and my battery went dead and now it will not recharge. I hav d right charger and it will not come on at all. I only used my phone a few times.
I had two black batteries that came with the phone (KA08) two years ago, and I bought another 2 white ones later. I kept them in storage last whole year, and when I took them out recently, 1 black and 1 white were still working, but the other two seemed not. However, after a persistent changing from the working to the non-working ones, I seem to revive the other two also. Therefore, the 4 are all working now. If there was any trick to that, I think all I did was while the screen was flashing, I switch the non-working ones in to sort of trigger the electrons if that was what. There was actually some hissing sound coming from the plugged phone without any battery, so I would not leave the phone plugged to the USB without the battery in it.
Jun 16, 2010 | Cell Phones
Sunfire gt. the car died :(
did you check the crank to see if the engine in locked
Feb 24, 2009 | 1997 Pontiac Sunfire
Keeps dying
Hi, It sounds to me like your alternator is breaking down this will need to be tested and replaced if it is faulty.
May 19, 2008 | 2000 Ford Expedition
46 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
