Question about Panasonic TH-50PX75U Plasma HDTV
TV wont come on
Every place I've checked talks a blinking power red light in front. My TV doesn't have the power on blinking red light when I turn it on but still wont show any picture. The day before it did this too. But I left it alone and came back to it and it turned on right away.
    Top Expert:
  • Panasonic Master
  • 75,462 Answers
Blinking power light indicates fault. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. These are called blinking codes. To know more about these blinking coded, visit the site. It has details about blinking codes to many brand TVs. Pull up older posts. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. http://electronicshelponline.blogspot.com/
Posted on Apr 23, 2013
  • 367 Answers
SOURCE: Panasonic plasma
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your picture problem,unless there is something else wrong.What is happening,is they are heating up,and the picture goes out.I bet the longer you have the TV off,the longer it stays on?Hope this helps.Thank You very much! Tyler
Posted on Apr 07, 2008
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
ginko
  • 19396 Answers
SOURCE: Power won't turn on; red lights blinks occasionally
It sounds like a bad PSU, or a bad solder joint on one of the boards.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
SOURCE: power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
Posted on Jun 11, 2009
SOURCE: red light power blinking
power supply problem this can be done by a professional tv repair
Posted on Sep 12, 2009
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Samsung dlp tv wont turn on, blinks lamp light green and temp light red
These blinks of LEDs are fault indications. If you wish to get more details about these blinking codes, check this link. The details are there. It is very difficult to include all those details in tables here by this window.
Feb 03, 2013 | Samsung HLN467W 46" Rear Projection HDTV
Need upstar TV Codes
I found that common LG codes (056) mostly work with UpStar (that uses LG panels, and generic electronics modules).
Watch out for stripped or missing hardware, including on table stand pod and VESA brackets, with UpStar's sloppy quality control. Also, they've reversed AC line Hot and Neutral and caused other problems in their California service facility, shipping fire and electrocution hazard TV's.
Aug 28, 2012 | Acer Televison & Video
My sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
Jun 22, 2012 | Sony Televison & Video
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
Tv wont turn on, the power indicator nor the remote receiver light does not light up, the 3rd circle on the front of the tv blinks red!! But it wont come on regardless, tv is only 2 years old, what to...
The blinking red light means set is in shutdown because of a short inside the tv.
Someone to begin would have to open it and check power supply voltages inside the set....that is the first step.
Mar 18, 2012 | Televison & Video
2001 Sony KP 61V90 61 inch rear projection TV has steady red power/standby light and thus is getting power, but doesn't fully turn on. I've read that this may be a fuse. Suggestions on repair?
Hello. I can help, but please could you tell me how many times the front LED blink?. After connecting and press power, see how many times the LED blink. are you sure the TV model is same as that spelling on your question?. send me your answer and will answer soon. thanks
Aug 14, 2011 | Televison & Video
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
Panasonic TH-50PX75U Plasma HDTV Logo
176 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
