Pc does not recognize my scanner
I have bought a new pc which operates with Windows Vista.Since then my pc does not recognize my scanner,brand ''artec'' , model :e+ pro'' and I can't find the appropriate drivers on the internet.The drivers that I have found are only compatible with Windows XP or previous editions.
    President:
  • 2,692 Answers
That usually means that the company has not written a driver for VISTA and usually with a discontinued  a model,never wil write one. Noone else will either.  It makes that model  scanner incompatable with VISTA. Their is no workaround.  Sorry.  Please don't rate harshly for me telling you the truth. Thanks.
Posted on Mar 12, 2009
I just bought this scanner and have windows vista hooked it up and nothing. i do not have a disk
How to get the Artec 1236USB/Ultima 2000 scanner working in Windows Vista. Note that this how-to skips the various UAC prompts that occur throughout the process.
1. Right click on the Setup executable (whatever the name is, also assumes the full 22MB file) and then select the Compatibility tab. Set compatibility settings to Windows XP (Service Pack 2), and set the program's Privilege Level to run as administrator.
2. Install the scanner drivers and reboot the computer.
3. Go into Control Panel, select System, then select the Device Manager. Select the scanner, which should appear as an unknown item on the list. Right click on the unknown and select Properties, then select the Driver tab. Select the Update Driver button and let it search for the Artec drivers. A warning will appear regarding the lack of a digital signature. Tell Windows to install the driver anyway.
4. Reboot computer.
5. Search for Scan32.exe or open an Explorer window and drill down to c:\windows\twain_32\artecusb\.
6. Right click on Scan32.exe and select the Compatibility tab. Set compatibility settings on scan32.exe to Windows XP SP2 and make sure the executable can run as an administrator.
7. If desired, repeat this process with ScnPanel.exe in c:\program files\artecusb\scanpanel\. My personal opinion is that ScnPanel.exe is redundant, the aforementioned scan32.exe file being far more flexible. It only serves to use up resources, so I wouldn't bother with making the file compatible and would just remove it from the Startup group.
8. Start scanning.
Hope this is helpful and fix the issue.
Thank you for contacting FixYa
*Please rate this solution with a thumbs up
Nov 16, 2010 | Artronix Technology Artec 1236 Flatbed...
Artec e+48u scanner problem
go to control panel, under device manager uninstall imaging device (scanner) and click scan for hardware changes, if found new hardware occurred click next and choose no, not this time tab / choose install from the list specific location option tab / choose don't search i will choose the driver to install / click show compatible hardware tabs and select scanner type appeared.
Mar 09, 2010 | Artec e+48u Flatbed Scanner
Is a Windos Vista driver available for Artec e+ Pro flatbed scan
No there is NO suitable driver for hardware this old.... Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. OR Windows ME, 2000 etc. Now apply the settings and run the installer. This should work for most drivers, but not all
Feb 23, 2010 | Office Equipment & Supplies
Need driver
Hello i hope u 'll be fine.
You can get the driver of Artec E+ 48U USB Scanner 4.12 for all operating systems like Windows 98/ME/2000/XP
  • To download the driver "Click Here"
  • You can also download the same driver from "Here"
When u click on any above link downloading will start. After downloading driver, Install it on Your PC and Enjoy
Wish u good luck
If it is helpful, Kindly Do Rate Me
Thanks for usingfixya.
Feb 16, 2010 | Artec e+48u Flatbed Scanner
Use scaner in windows vista
Here is a third party scanner program that works with almost any scanner. http://www.hamrick.com/
Jan 21, 2010 | Artec e+48u Flatbed Scanner
Do you have the Vista Drivers for the Artec e+48u Scanner, please?
You can try this solution, but it may not work. As of this time there is no support for your scanner with Vista from the manufactuar.
1) download the xp version driver by going to this link and choosing the Full Version.
http://artectv.com/Service_e/nl/home/Old_drivers.htm
2) right click the exe icon.
select properties , then compatibility and choose xp service pack 2.
Right click again and RUN as administrator
allow this program to run even though it has not been aproved by microsoft.
3) go to c:/windows/twain_32/ePlusPro/Scan32.exe
right click SCAN32.exe
select properties, then compatibility and choose XP service pack .
Right click again and RUN as administrator.
I actually created a shortcut to the desktop of scan32.exe.
Now everytime i click on this..........my artec e+pro scanner work absolutely fine.
The only problem is none of the shortcut butons work on the front of the scanner , but you can choose where to save the image to through the Twain program, then edit it it whatever program you require.
Dec 20, 2009 | Nikon Coolscan IV ED Film Scanner
Hi i have a some of queries i want to download driver of the scanner artec ultima 2000
You can download driver for Artec Ultima 2000 here:
Artec Ultima 2000 driver
But, this driver is for Windows 98/ME/2000/XP. Unfortunately, there is no driver available for Windows Vista.
Please rate the solution...
Thank You
Nov 14, 2008 | Office Equipment & Supplies
Problem
Take a look here
http://www.driverforum.com/scanner4/7720.html
However if you are hoping to run it on an XP/Vista machiner you may be unlucky
Mar 19, 2008 | Office Equipment & Supplies
168 people viewed this question
k24674
jasbo
jasbo
