Question about RCA P60921 60" Rear Projection Television
No power on RCA p60921
TV was on and the power went out for an hour or so. When the power came back on, the TV won't turn on. I checked the fuse (5MF5A125V) and it looked good. I replaced with 5A 125V fuse (but it isn't a fast blow that I got at Home Depot) and it still won't come back on. Any ideas?
  • Anonymous Dec 27, 2007
    Philips tv 43pp92 0217 won't power on, Home Depot tested the fuse and said it was good. Any help would be greatly appreciated.
    Yolanda
  • studderboy Jan 15, 2008
    My T.V. doesn't power on, I shut it off and never came back on. put new fuse in, don't know what else to check. If anybody has had this problem please let me know what to check. thank you Brian Haines.
    Problem Solver:
  • 5 Answers
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Posted on Oct 13, 2007
SOURCE:
I have a rca p60921 projection tv and i went to a television expert and they told me it was the transformer, i juat want to know where it is located and what is the part number and serial so that i can...
Tranformer is the power supply unit follow the cord in you cannot miss it. The number is stamped on that transformer I do not have the P/n in frount of me to tell you but, you should be able to contact the manufacture for the number.
Thanks I hope this does help pleas edo leave a rateing for your free answer today!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 29, 2009 | RCA P60921 60" Rear Projection Television
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
RCA P60921 Rear Projection TV
converge power supply small pcb about 3 inch by 7 inch with stk-730-xxx chip on it ..replace the chip
Oct 29, 2008 | RCA P60921 60" Rear Projection Television
Rca no picture no sound
There is no sound on my rca 60 tv. what can I do. The movel number is P60921.
Jul 30, 2008 | Televison & Video
Chassis no PTK195MT
This part is called the flyback transformer and is part # 239111 at a cost of $68.99 from tritronicsinc.com. You can replace the transformer. It sounds like it developed a short internally. There may be other parts that were effected as well. If you are not comfortable working inside hte set, expect a service call to run about $100 for parts plus hte local labor rate.
Dan
Jun 09, 2008 | RCA P60921 60" Rear Projection Television
Tv wont come on
do you have a chassis number? example PTK169PGB
CTC169PGB
Mar 26, 2008 | RCA P60921 60" Rear Projection Television
RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Jul 27, 2007 | RCA P60921 60" Rear Projection Television
No picture
need chassis # ctc something look for it on the back cover
Jun 19, 2007 | RCA P60921 60" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
267 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
