Question about Samsung SGH-J600 Cellular Phone
How to recover samsung m2710 from 18000007 error
When i switch on it a red color blinking 18000007 comes it doesn't start please tell me the solution
Samsung m2710 password unlock please help me
Posted on Mar 29, 2014
Pn51f4500af samsung plasma 4 red blinks no video
These flashes are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 16, 2015 | Samsung 50 in. Plasma TV
I have a ml-2165w laser black printer, when try to print it tells me me disconnect and press on button, the light turns green then blicks then turns red. What do I do>
Dear
There may be some error related to fuser or LSU.
Pl. down load samsung easy printer manager from samsung site or it can found on the disk provided.
run it it show the error detail.
Thanks
Oct 06, 2014 | Samsung ml-2165w - laser printer -...
Samsung PN58c590 plasma tv
Short circuited component/s at its main board. These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Samsung PN58C590 TV
Hi guys i have a Mitsubishi WD-65C9 DLP that gives me nothing but a few seconds of audio before shutting off with a blinking red light. ERROR 61
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 27, 2017 | Mitsubishi WD Televison & Video
Sony Grand Wega Projection TV 2005 Replaced lamp in it, turns on but screen doesn't do anything and the red light next to the power button blinks. I think it just needs a new color wheel but I...
Take a close look at the red light blinking to see if it blinks in a sequence, for example 4 blinks, pause and repeats the sequence, that would be an error code.
Dec 17, 2012 | Televison & Video
My hp compaq doesn't work when i branche the cable of alimentation it signe with red
How many times does the red light come on ? It should blink a number of times, then go off for a little while, and start blinking again. The number of blinks within each cycle will help you find out what is wrong:
Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
(http://h18000.www1.hp.com/products/quickspecs/productbulletin.html#spectype=worldwide&type=html&docid=11632)
Jul 07, 2012 | HP Compaq d530 CMT PC Desktop
Samsung HLN5065W
Apr 12, 2017 | Samsung HLN5065W 50" Rear Projection...
My microwave oven from LG MG 604 W has now starting problem, when we open the door the light is on and even the display is okay we can set the timer but when we press the start button it doesn't start...
The owner's manual should tell you what that symbol means.
If for some reason you don't still have yours, you can download it here.
I would suspect a bad door switch or door switch mount.
You should see my text file on door switches for more information.
You can order LG parts from Encompass here or you can call them toll-free at 866-779-5835.
Sep 26, 2011 | Cuisinart CMW-100 Microwave Oven
Switch on the printer and it goes through its cycle and a red light comes on. With the black toner blinking. I have changed the toner switched on and this time just the red light comes on. Samsung...
unplog the printer from electrik for 10 minutes and try aggain, if the problem still occure try to update the soft ware using the web side from samsung for this printer, this should solf the problem.
Apr 18, 2011 | Samsung CLP-315W Laser Color Printer
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
Samsung SGH-J600 Cellular Phone Logo
178 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
