Question about Rosetta Stone French Level 1 & 2 Set 3 Full Version for PC, Mac (794678211959)
Rosetta stone is not letting me turn on why
It worked Before and then one day it suddenly didn't let me go on it says this RosettaStoneVersion3.exe - Entry Point Not Found The procedure entry point sqlite3_prepare_+v2 could not be located in the dynamic link library sqlite3.dll. Does any one have any suggestions?????
laikexpert
  • 281 Answers
SOURCE: Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Posted on Jan 04, 2010
MUKHTAR
  • 2017 Answers
SOURCE: My Rosetta Stone version 3 stopped working and
just reinstall the Rosetta Stone application.
Posted on Jan 20, 2010
  • 10 Answers
SOURCE: my rosetta stone cannot or will not recognise that
The disk may be defective or there may be other problems that cannot be diagnosed given the information that you have provided. The best solution would probably be to call Rosetta Stone's free tech support directly at 1-800-767-3882. They can provide step by step problem solving and can help you find a solution.
Posted on Mar 03, 2010
SOURCE: I fave a microphone in my web camera. And Rosetta
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
Posted on Apr 27, 2010
SOURCE: Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
Posted on Jul 20, 2010
Rosetta stone on Mac doesn't open because of error 9120
Go to System Preferences (click on the apple in upper left corner of monitor and pull down)
Look for "hardware" and click on "sound". Is your mike on? Make sure your "output" level is high.
Hope it helps!
Feb 22, 2013 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
Rosetta stone error code 3217
You should contact Rosetta Stone's customer support directly. They are excellent in helping with your computer issues. Phone number is 800-280-8172.
Sep 25, 2012 | Rosetta Stone Spanish (Latin American) -...
Hi I am after activation code for Rosetta stone version 3 French levels 1-5 Thanks
You can find the rosetta stone activation key in the link below
http://extratorrent.com/torrent/1419538/Rosetta+Stone+V3+Crack+Patch+Serial+Keygen.zip.html
Jun 16, 2011 | Rosetta Stone French Levels 1 & 2 Full...
Rosetta Stone Starts but the home screen in blank
Sounds like you saved your progress file in a non Rosetta Stone folder and now it can't associate the progress with any language packs.
Mar 09, 2010 | Rosetta Stone V3 Spanish (Latin America)...
I have Japanese levels 1,2 and 3 for rosetta stone. i installed all the software and entered the activation code. it says my codes are activated but when i open the software i only get a blank screen with...
The problem is related to the FNPLicensingService.exe service and FNInterface.dll file.
The first thing you can try is open Rosetta Stoneto and kill the FNPLicensingService.exe in task manager. This may or may not give you access to Rosetta Stone.
If that doesn't work, install Rosetta Stone on another computer (your license will allow two machines) then copy the rosetta stone directory from program files to the new system. Then open Rosetta Stone and it should be fine.
Before doing either of these things it's best to delete the c:\program data\rosetta stone\tracking.id file.
Aug 06, 2009 | Rosetta Stone Japanese Level 1 & 2 for...
or
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
How can I fix error 1117 problem with speech component. I have tried restarting the browser and the computer.
This will fix IF you are running a personal firewall:
Enable the Rosetta Stone app to communicate within a trusted area. This lets the app send data to the computer that it is running on. An example might be port 127.0.0.x. You can still block it from communicating with the internet if you like.
In my case, I run the Sunbelt Personal Firewall. I went into its configuration panel, clicked on the Network Security tab, and found the Rosetta Stone Ltd. executable entry. Then I ensured that a green "permit" checkmark appeared under the Trusted Out column. Apply and close. Restart RS and the speech component should work.
-Mike
May 04, 2009 | Rosetta Stone Spanish (Latin American) -...
Error 2123 when i enter app
You may get this problem if you have BitDefender Internet Security. To fix it:
Open BitDefender, click Settings, set UI to Expert Mode. Click OK.
Select Antivirus, Advanced Settings then under Exclusions click [+] symbol, a browser opens, go to the following; C:\Program Files\Rosetta Stone\Rosetta Stone Version 3 and select the RosettaStoneVersion3 file, click OPEN. Then OK. Sorted.
May 03, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Rosetta Stone French Level 1 & 2 Set 3 Full Version for PC, Mac (794678211959) Logo
21 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jax Planet
Jax Planet
IT GURUS OF ATLANTA
IT GURUS OF ATLANTA
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
