Question about Sys Technology SYS 17-C-MT (Chrome) 17 in. Flat Panel LCD Monitor
Fixing my 17-c-mt lcd
I have a 17-c-mt sys lcd and the problem with it is that when i turn it on it displays everything good after about 5 minutes the colors start to flicker, the black areas turn green almost like a tv without signal. If you can help me with this problem I would really appreciate it thank you.
17-C-MT MONITOR
Hi.
Connect speaker cable from the monitor to the computer tower.& restrat the computer
Thanks
Aug 25, 2009 | Sys Technology SYS 17-C-MT (Chrome) 17 in....
When turn on color is great..after a few minutes turn blue and green
Sounds like the lcd is bad but here is a way to verify that. Hook up a known working monitor to the computer, if the colors stay great after a few minutes then you know the original monitor is good.
If the colors turn blue and green after a few minutes with the working monitor then you know for sure that the video card is bad and the video card would need to be replaced.
Aug 23, 2009 | Vision V1721B (Black) 17 inch LCD Monitor
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
White Display
Here is two solutions:
1. Grab a LCD Color Tester, Run it through RGB.
- If it is still white its the LCD
-If it not at all either the inverter board is bad or the mainboard.
2. Sometimes its brightness control, look under the manual.
Apr 18, 2009 | Princeton Digital VL1716 17" LCD Monitor
Acer aspire display faliure
maybe the inverter of your lcd is damage
Mar 12, 2008 | Acer Aspire 5050-3242 Notebook
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Dell monitor problem
hey buddy, its seems to be the display driver problemi think..
please install the correct display driver for your VGA card in the CPU.. let me know?
Dec 13, 2007 | Dell E173FP 17" LCD Monitor
Won't Turn On
Possibly a capacitor on the internal board for the monitor that will not stay energized to allow the backlight for the monitor to illuminate. Going to need a qualified technician with the tools and equipment to diagnose it first hand. If you are not sentimentally attached to the unit, you can pick 17" monitors up pretty cheap these days.
Aug 26, 2007 | Sys Technology SYS 17-C-MT (Chrome) 17 in....
Sys Technology SYS 17-C-MT (Chrome) 17 in. Flat Panel LCD Monitor Logo
Top Sys Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Sys Technology Computer and Internet Expert? Answer questions, earn points and help others
