Question about E-Machines eMachines Desktop PC
EMachine EL1333G windows 7 64 bit AMD Athlon 2650E Processor ( BIOS OVERCLOCK HELP)
If I overclock my AMD Athlon 2650E Processor 1.6GHZ (15watt) What is the maximum setting I can set, without causing any damage to the computer, or even having to worry about it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
What type of cooling do you have currently? How fast do you want it to go? What options does your BIOS offer?
Posted on Apr 12, 2014
How to overclock amd cpu
You question is a bit vague, type of AMD processor?, it's a bit more complicated, take a look at this: http://apcmag.com/free-your-amd-how-to-overclock-amd-in-5-easy-steps.htm
Apr 29, 2013 | Computers & Internet
Troy,
When Processors (CPU) are made, they are made on a Pass/Fail scale. Processor is either Good, or not good.
This means you may get a Processor that is on the Top of the scale, or Bottom of the scale. The AMD factory doesn't discriminate.
In fact they don't care. (This goes for all Processor manufacturers, not just AMD)
All they care about is does the Processor work, or not?
Therefore, you may have a Processor that is on the Bottom of the scale, but passed as Good.
Point? Stating a setting that might be good for joeblow's AMD Athlon 2650e, may not work for yours.
Might work for yours, and not joeblow's.
This is why you need to go into BIOS Setup, and using a SMALL increment, overclock the Processor.
Run the computer for 24 hours, and see if everything is chiily.
(Computer still works OK)
This is a "Burn-In test"
Works OK for 24 hours? Then go back into BIOS Setup, and go up one more small increment. Do the Burn-In test.
Keep going until the computer has glitches, or doesn't work.
Then go back into BIOS Setup, and come down one small increment, or go back to where the computer WAS working OK.
It's an individual thing. Each Processor (CPU) is different from the others.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 23, 2013 | E-Machines eMachines Desktop PC
Amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
How to get AMD athlon 3700 socket 754 engineering sample cpu run at proper speed
Here's a little history
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
More advanced stuff
http://compreviews.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=compreviews&cdn=compute&tm=128&gps=215_11_1267_540&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=2&bt=0&bts=0&zu=http%3A//www.adriansrojakpot.com/Speed_Demonz/BIOS_Guide/BIOS_Guide_Index.htm
Some systems have "bottlenecks," where small overclocking of a component can help realize the full potential of another component to a greater percentage than the limiting hardware is overclocked. For instance, many motherboards with AMD Athlon 64 processors limit the speed of four units of RAM to 333 MHz. However, the memory speed is computed by dividing the processor speed (which is a base number times a CPU multiplier, for instance 1.8 GHz is most likely 9x200 MHz) by a fixed integer such that, at stock speeds, the RAM would run at a clock rate near 333 MHz. Manipulating elements of how the processor speed is set (usually lowering the multiplier), one can often overclock the processor a small amount, around 100-200 MHz (less than 10%), and gain a RAM clock rate of 400 MHz (20% increase), releasing the full potential of the RAM.
AMD also produced x86 designs which competed with Intel on performance rather than price. In January 2002 the Pentium 4 gained a lead in sales and AMD marketing responded by giving their processors numeric suffixes approximating the clock rate that an AMD Thunderbird (and by inference a Pentium processor) would need to give matching performance, openly undermining the "megahertz myth".
May 15, 2009 | Computers & Internet
Overclocking
I never overclock my processors... because I have fried a couple.
AND I don't really need any extra power/speed... because now I only surf the web and do some Word/Excel stuff and my duo core Intel chip is awesome for that.
So - first: I don't recommend it.
But - second: there are some good sources on the web about it...
Do you know how to do it?
I mean the steps to get to the settings and change them?
If you do then I found some recommendations for your processor at http://www.amdgeeks.net/overclockdatabase.
Processor: Athlon 64 LE-1640 2600 @ 3422 MHz
Overclock % Voltage Idle Load
132% 1.25/35/40 @ 1.50V 35°C 41°C
Processor: Athlon 64 LE-1640 2600 @ 3380 MHz
130% 1.25/35/40 @ 1.40V 30°C 40°C
Processor: Athlon 64 LE-1640 2600 @ 3320 MHz
128% 1.25/35/40 @ 1.37V 29°C 44°C
Like I said I don't recommend it so I don't want to walk you through it, also when you do this you run a risk of frying your chip - and I don' want to be liable. Like I said above - there is some good infor on the web about it so you should not have any trouble finding out how if you don't know.
Good luck
Jan 03, 2009 | Acer Computers & Internet
Foxconn or my processor fried while i tried to overclock my comp
Foxconn are miserable at overclocking and X2 - 6000 is a proc already overclocked from factory - you can't push it any further without a serious water cooler.
Reset the BIOS and hope it will start again, otherwise you will need at least a new proc.
Dec 24, 2008 | Computers & Internet
Overclock procesor athlon 64 2800 +?
There are a bunch of guides out there to help you with the overclocking process.But bear in mind that you will loose your warranty as son as you change the frequency cycles. Also make sure that your system can withstand the excessive heat that will be generated by the processor.You should arrange some alternative cooling system like liquid coolers,Highgraded thermal insulation pastes or atleast a couple of additional coolant fans. Go through this.... http://www.hardwaresecrets.com/article/102
Nov 03, 2008 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Can the amd athlon 4200 x2 proceesor be overclocked ? on the geforce6100pm-m2 motherboard
not a good idea over clock it to much without the right cpu heat sink and faster fan will make it over heat and possably blow up it should work with 2.4 if not u need at least a 450 watt power supply with that card
Oct 26, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Overclock a black edition 5000 x2
@johnhercus26
pls let me remind you that overclocking voids your pc's warranty.you will need to enhance the cooling solutions for the device you will overclock plus the cooling solutions for the CPU case, every time you overclock, more heat is produced by the device you are overclocking. also you have to make sure you have power headroom..., a higher wattage CPU power supply. plus the risk that you may toast your pc or lessen its usable life. overclocking is for advanced users so pls take extra caution if you will do it.. for guide and instructions pls click here and goodluck! >>> http://www.pcstats.com/articleview.cfm?articleID=1804
Oct 23, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Sandrew
There are different ways to overclock, however some methods might harm the CPU I am adding the link which shows the methods. here is the link
http://www.amdboard.com/ocspecial.html
Also please make sure your BIOS supports overclocking
Good Luck
Jun 19, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
E-Machines eMachines Desktop PC Logo
85 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
