Question about Ovens
Kic ovens Good day, I have a KIC Megatron oven and hob MOdel UCC 112. I am looking to remove and replace the oven door.Could someone point me to a manual. Greg
3 Suggested Answers
  • 244 Answers
SOURCE: KHO KIC KUCO600B 60cm BLACK Undercounter Oven and Hob set
south africa, or australia? get online to the manufacturers website and inquire!
good luck!
Posted on Oct 19, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: I need to replace a
Sorry to read about your problem, I hope this helps you out.
most of them do not have a fuse
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
HOW DO YOU REMOVE MEGATRON
its magnetron not megatron.
if you know how to work on electrical device then only read the instruction otherwise leave the page.OVEN HAS 5000 VOLTS
1.remove right side pannel
2. remove foil tape
3.two magnetron are present select either one
4. remove four 10 mm mounting screws
and remove electrical harnesses
5.you did the job ver well
thanks
please rate my work
Jul 07, 2011 | TurboChef TORNADO Electric Oven
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
I need to replace a fuse in my KIC oven but I cannot find where the fuses are? Please help. Many thanks Les
Dec 23, 2010 | Ovens
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
good luck!
Oct 19, 2009 | Ovens
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Can't find the fuse for the oven
    I doubt this is a fuse problem. Could be the heating element has failed.
    Apr 21, 2009 | Ovens
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
