Question about Frost Refrigerators
Frost free refrigerator sharp sj - 434FG/FA/WG/WA wiring diagram
    Guru:
  • 147 Answers
Are you sure of model num
Posted on Jun 30, 2015
  • 12 Answers
SOURCE: IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
You have a defrost problem. You need either the defrost timer, defrost heater, or the defrost bi-metal. If you have a meter you can ohm out the heater and the bi-metal ( as lonh a s the bi -metal is frozen as it opens when it gets warm to cut out the defrost heater) if you have an ohm reading on either one of the two the replace the defrost timer, if you don't then replace the part that has no ohm reading.
Posted on Sep 14, 2009
  • 7 Answers
SOURCE: My frost free refrigerator has frost even with
your freezer is getting frost because the door is not closing all the way. Make the necessary adjustments to the door so that it gets a good seal and the frost should stop
Posted on Nov 05, 2009
  • 16 Answers
SOURCE: Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Posted on Jun 10, 2010
aviral_srms
  • 1216 Answers
SOURCE: could you please supply an
here is the diagram.
note this is a general wiring diagram for westinghouse refridgerators and depending on your model may be there are some small changes
if having problems viewing image , click here
Posted on Oct 09, 2010
  • 430 Answers
SOURCE: sharp SJ-F80SP-BK 4 Door refrigerator
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Posted on Jan 31, 2011
Sharp refrigerator Model SJ-TD555S. Fridge won't cool. Freezer section frosted over and not defrosting.
You are not getting enough air flow over the coils. First, unplug it so it will defrost. Vacuum coils (back or underneath). Do not cover up the air vents inside the refrigerator. Check if the compressor fan is spinning. If all fails, you may have a refrigerant leak.
Apr 12, 2017 | Sharp Refrigerators
We have sharp refrigerator. It has 4 doors. The upper refrigerator not working. The freezing down is O.K.
If you wish to get some details about refrigerator repair check the following link ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 03, 2017 | Sharp Refrigerators
Sharp sj-19tgl refrigerator not cooling
Checked Thermostat and replaced.
Jan 03, 2014 | Sharp SJ-19TGL/DL
In the freezer compartment, there is frost in the back. It's a side by side 19.9 without a water dispenser. The refrigerator part is not as cold as it should be but it is cold.
although most frost free freezers will hardly ever frost up,some will,(it depends on overall humidity)by frost free the makers say "food is frost free"but the inside is shinny plastic and all shinny surfaces will collect condensation and frost up.(look under the salad crisper,condensation?)it is worthwhile, about once a year,doing a complete defrost(NO sharp objects)and vacuum out all the vents/clean out any drain holes.
saves you a fortune in power.......
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
hello sir/mam
please check the blower of the refrigerator if this is not working the refrigerator wont get cold.
Sep 14, 2009 | Refrigerators
I have a 4 door sharp SJ-F60PC Refrigerator and the door of the crisper that comes up when you open the crisper draw has broken need a new one
From my search the only Sharp Regrigerators are sold in Australia and NZ. Here's the list of spare parts outlets:
State Spare Parts Wholesalers Contact Details Queensland Prime Electronics- Bowen Hills
24 Campbell Street
Bowen Hills QLD 4006 Phone: 07 3252 7466
Fax....: 07 3252 2862
Email: mail@prime-electronics.com.au New South Wales Prime Electronics- Flemington
185 Parramatta Road
Flemington NSW 2140 Phone: 02 9704 9000
Fax....: 02 9746 1197
Email: mail@prime-electronics.com.au South Australia Statewide Appliance Spares
178 Sturt Street
Adelaide SA 5000 Phone: 08 8231 3369
Fax....: 08 8212 3195
Email: service@statewideapp.com.au Victoria Speedy Spares
451 Macaulay Road
Kensington Vic 3031 G.B. Telespares
5 Hunt Crescent
Clarinda Vic 3169
Phone: 03 9376 1333
Fax....: 03 9376 7110
Email : speedysales@bigpond.com Phone: 03 9512 7604
Fax....: 03 9512 7534
Western Australia WA Appliance Parts
135 Russell St
Morley WA 6062 WA Appliance Parts
1/9 Blaikie St
Myaree WA 6154
Phone: 08 92754755
Fax:...: 08 9275 4935
Email :parts@waapplianceparts.com.au Phone: 08 9330 1999
Fax:..: 08 9330 1677
Regards and hope this was Helpful,
Worldvet
Jun 01, 2008 | Refrigerators
Refrigerators Logo
100 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
Charles T Nevin
Charles T Nevin
Mike
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
