Samsung N150 Netbook Logo
Anonymous Posted on Apr 23, 2013
Turn of keyboard clicking sounds
Just recently a clicking sound has started each time I type which is most anoying.how do I stop this function?
hamid iqbal
Level 1:
Habit-Forming:
New Friend:
  • Contributor 23 Answers
  • Posted on Apr 23, 2013
hamid iqbal
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
23
Questions
0
Helped
14353
Points
61
Just chang keyboard
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    My samsung n150 plus keyapd is not working properly
    It sounds like a key gets stuck on your keyboard, which keeps sending signals to your computer; especially as it seems fine using an external keyboard. When the laptop is off, try typing on each key a number of times, especially the 'suspect' ones, m and 0 (?)
    Have you spilt Coke or coffee on it at any time??
    68helpful
    5answers
    My keyboard will not type a double letter or backspace more than once without stopping first? Do you know why?
    Disable Filter Keys in Windows 7 and Work.If Filter Keys has turned on in Windows 7 and your keyboard is no longer responding as you would like, follow these directions:
    1. Click Start
    2. Click Control Panel
    3. Click the Ease of Access heading.
    4. Click Change how your keyboard works.
    5. Remove all the check mark in the box next to "Turn on Filter Keys".
    Enjoy :)
    ~ Vikrant (India)
    2answers
    No sound
    Try this:
    Click Start, select Run, type "services.msc" without the quotes and press Ok. Services window will open up. In that window, select the Windows Audio Service and the status and startup type of the same. In case the startup type is disabled, double click on it and select the startup type as Automatic. After that right click on this service and click Start. In case the Start is greyed out, click on Restart. Now check for the sound.
    I have turned off the sound conrols on my Compaq keyboard
    To turn on your sound control, perform the following steps:
    Press Windows Key and R key simultaneously to open Run window.
    Type mmsys.cpl and click on OK.
    Uncheck the Mute option if it is checked.
    Click on Advanced tab and move the sliders to the top position.
    Also enable back the windows startup options as they are required to be running for windows to function properly.
    Follow the steps in the below link if you are experiencing audio issue in your notebook:
    http://notebook-solutions.blogspot.com/2009/05/no-audio-in-notebook.html
    20helpful
    2answers
    I can't turn off the keypad tones on a LG Xenon phone
    To turn off the beep on the keypad beep or voice on an LG Xenon, go to menu; settings; sound; volume. From there you can raise or lower the volume or mute the keypad and other sounds.
    3answers
    No audio sound after installing the keyboard software
    when you loaded the software for the keyboard, the buttons on the keyboard for functions will be active, have you made sure that the mute key on the keyboard is not pressed 'on' to mute the sound?
    2answers
    Keyboard buttons clicks before typing
    Sounds like he may have turned on the "Sticky Keys", to turn this off , tap the shift key 5 times....should take care of it!
    Top Samsung Computers & Internet Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Jean Thiebaux
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
