Question about Cell Phones
Midea induction cooker model ef197
When switched on the beeper keeps going off - the cookware is correct - the cooker doesn't get hot after a short while the cooker switches off
SOURCE: Tricity Bendix cooker oven is not getting hot
Element needs replacing
Posted on Dec 27, 2008
SOURCE: Vollrath induction cooker is not working. The display reads F9. Model # is 59500.
The range does not recognize the pan material. Only ferrous (magnetic) cookware will work with induction. This is a protection circuit to only heat proper cookware. When all else fails read the instruction book or call the service department for the manufacturer...save time, reduces frustration and assures safe operation. Good Luck
Posted on Nov 19, 2009
  • 2523 Answers
SOURCE: My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Posted on Jan 16, 2010
  • 4 Answers
SOURCE: I have pigeon induction cooker.
what about steel/iron utensils?
Posted on Feb 15, 2011
BElectric
  • 1140 Answers
SOURCE: My Zanussi Induction cooker model ZKT 621LX is not
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
Posted on Apr 19, 2011
No matter what pot we use, it wont work
Most cookware found found in home today is aluminum or cast aluminum. These do not work on induction cook tops. Even older stainless steel Farberware doesn't work because it is not magnetic. Look for an induction compatible label or stamp on the cookware to be sure.
Induction cookware must be made of a magnetic-based material, such as cast iron or magnetic stainless steel. Fully clad cookware brands, such as All-Clad Stainless, Le Creuset Stainless Steel and Mauviel M'cooks stainless work on induction cooktops because they're magnetic.
Mar 15, 2015 | Eurodib Induction Cooker
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
Induction cooker
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel) If you have the correct pots then it will need a repair.
Sep 25, 2013 | Winco Professional Induction Cooker -...
Induction cooker
follow this instruction .God bless you
  1. E0 Error
    • 1
      Put a pan on the cooktop surface if you receive an E0 error. This error indicates the absence of cookware on the ceramic surface.
    • 2
      Remove your cookware if you are still receiving an error.
    • Sponsored Links
    • 3
      Hold a magnet next to your cookware. If the magnet sticks to the cookware, it is appropriate to use with an induction cooktop.
    • 4
      Place the cookware back on the cooktop if the magnet sticks, or replace it with appropriate cookware if the magnet does not stick.
    E1 Error
    • 5
      Turn off the cooktop.
    • 6
      Remove the cookware from the cooktop.
    • 7
      Unblock any external ventilation slots.
    • 8
      Let the cooktop cool down for at least 10 minutes.
    • 9
      Place the cookware back on the cooktop and turn it on again.
    E2 Error
    • 10
      Check to see if there is any food in the pan.
    • 11
      Place food in the pan if there isn't any in it.
    • 12
      Turn the cooktop off if the error does not disappear and let it cool down for at least 10 minutes.
    • 13
      Resume cooking by placing the cookware back on the cooktop and turning it on again.
    E3 Error
    • 14
    • 15
      Check your house's fuse box for blown fuses, tripped circuit breakers or voltage fluctuations. Replace any blown fuses and reset the tripped circuit breakers if necessary.
    • 16
    • 17
      Turn the cooktop back on and resume cooking.
Read more: http://www.ehow.com/how_7492378_troubleshoot-summit-induction-cooktop.html#ixzz2Ze1uo0as
Jul 20, 2013 | Heating & Cooling
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Have lost iinstructions for tefal optima pressure cooker, do not know what positions 1 & 2 indicate
http://www.tefal.co.uk/Consumer+service/Use+instructions/use-instructions_home.htm
go to this site select and download the manual you will know it all.
regards.
PLZ. RATE
Jul 03, 2011 | Tefal Food Processors
What type of cooking vessels are needed to use on the Technika cook top which is induction heated .
it only works with cooking vessels made of magnetic materials. The commonest such materials used for cooking vessels are stainless steel and cast iron. Cookware suited for use with induction cookers, from the extreme high-quality end down to thrift-store modest, is readily available; but if you already have a stock of mostly expensive aluminum or copper or glass or pyrex cookware and little or no cast iron or stainless,
Dec 19, 2010 | Ovens
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
Oct 03, 2010 | Westinghouse Microwave Ovens
Apr 18, 2009 | Kitchen Ranges
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
