Question about Refrigerators
Model QD 22 Z
This gas fridge/freezer is 25 years old; needs new baffle for the flame tube. Where can I source one?
  • 77 Answers
SOURCE: Air Baffle sticks in Kenmore Elite refrgerator
look fo an air leak. could be at ice cube chute door on freezer.
Jim
Posted on Jul 27, 2008
  • 254 Answers
SOURCE: freezer has bad smell, cleaned entire fridge and
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website. on  www.repairclinic.com
Posted on Mar 31, 2009
mark_37388
  • 100 Answers
SOURCE: Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Posted on Apr 03, 2009
SOURCE: fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Posted on Dec 20, 2009
SOURCE: New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Posted on Jul 10, 2010
My Finch fridge not getting gas to the burner.
If the gas is not passing the press down valve your valve is faulty and should be replaced you should also replace the thermo coupler which goes down to sense the flame in case the flame goes out it shuts off the gas. You should not attempt to replace this valve yourself and should get a qualified gas engineer.
May 01, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
I have a Dometic 2193 3 way fridge. It works
The flue baffle was the solution that worked for me as well. Below is a response I posted to a similar post.
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Jul 14, 2010 | Dometic RM2193 Compact Refrigerator With...
I have a freezer that does not work it clicks on for a few sec then cuts off what could be wrong
The clicking is the electronic ignitor trying to light the gas.
Either it's not getting any gas to light , or the flame sensor is not telling the computer that there is flame , so it shuts down the gas.
Most fridges have a small shut off right at the gas valve in the back of the fridge , it might be turned off. Put your ear up to the back cover of the fridge , if you hear it sparking and then you hear flame but it goes out after a few seconds , than it is the flame sensor. If you never hear the flame blowing , than it is not getting gas. Could be several different reasons. If you have disconected your tanks , maybe the gas has just not made it to the fridge yet. Newer ignitors try 3 times and then shut down if no flame is detected. Old ones only try once.
Apr 27, 2010 | Thetford Norcold RV Cooler/Freezer
Light not working in GE chest frezer it is larger than the model below, 22 cf, it is 25 years old.
Check the bulb, check the tabs within the socket, check the door light switch.
Please, unplug fridge when testing these. We'd like to hear from you again.
Mar 27, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Not cold enough
this could be just a thermostat problem or the unit may need to be "re-gased" and a new compresor
however its 25 years old???? dont you think you have had your moneys worth out of it yet??? its going to be a lot cheaper to buy yourself a nice new unit
ps,,your food wont keep in your freezer unless its at least -18 begrees F,,,, but take hart,,look at the funny side of life,,,at least you can still make yourself some hot drinks in the fridge ??? ha ha sorry!
Jan 17, 2010 | Refrigerators
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as...
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Jul 01, 2009 | Grilling
Bought a chescold finch 3 way fridge but no instructions - help
The max/min gas flame is for adjustment of temperature when using the fridge on gas. The next one with 0 to 7 is possibly the electrical thermostat. I am not familiar with this exact model. One of the dials will be able to be pressed in. The idea is to press and hold this button in for about a count of five, then push the lighter strike. You will hear a click noise which is when a spark is delivered to the burner area. Some fridges have a small window or guage which shows if the flame has lit. You may have to look down the chimney. You keep holding the press button down after having depressed the lighter strike button for about five seconds. This allows gas to flow to the burner while the thermocouple heats up. Once the thermocouple (which is a small copper probe sticking almost into the flame) heats up, it will keep the gas valve open and if you then release the button, the flame will continue burning. The idea is that if the flame were to blow out, the thermocouple would cool and in turn act as a safety by shutting off the gas supply. Hope this is enough info.
Mar 05, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fitting a Zanussi fridge thermostat
the stat is clamped to the backplate of the frodge with a simple clamp held just by two screws. undo the clamp. the stat capiliary may be bent back on itself, if so straighten it and it will pull out
Aug 16, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
