Question about Video Game Consoles & Games
How to turn orange light off
Put into 4wd mode and now it won't stop flashing and wheels are locked
  • 3,287 Answers
I don't know which particular vehicle this indication is showing on, but generally a flashing 4WD indicator is to alert you of a problem. This would be particularly true if it is on solid to indicate that 4WD is on, and off when in 2WD mode. Some manufactures have a traction control system that defaults to ON, and if switched off, will flash an indicator on the dash.
The best thing to do is to consult a trusted mechanic or your car's Owner's Manual. If you do not have access to the manual, please provide the year, make & model of your car - and I'll see what I can find out.
Posted on Apr 23, 2013
2 Suggested Answers
MitchMatch
  • 92 Answers
SOURCE: Hi My PSP's orange ligth won't turn off
Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick. Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ). However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems) Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card) If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
Posted on Jul 26, 2011
Tires changed and now 4wd lock flashing
Did you have same size tires put on ? With the light flashing there is a DTC'S - diagnostic trouble code stored , have to have diagnostic tool hooked up . That's the only way your going find out what the problem is .
Jan 16, 2013 | 2007 Mitsubishi Outlander XLS
On the dash of my 92 pajero the two front wheels keep flashing green when its not in 4x4 how ever i degreased under the engine and gearbox and realised after.that the lights had stop flashing until my son...
4X4
On these issue, there are few solved help links for troubleshooting the issue easily.-------
Click the link below: ---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing
4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
Nov 28, 2012 | 1992 Mitsubishi Pajero
4wd low light flashing on 2007 5.9 dodge mega cab but won't engage
The light is flashing because there is a problem in the system controls for the 4 wheel drive. You now need to have the control module scanned for fault codes and the correct diagnostics performed for the codes received to repair the problem.
Jun 27, 2012 | 2007 Dodge Ram 2500 Mega Cab Laramie
2005 Blazer key won't turn in the ignition
You may want to try to slightly push / pull your vehicle to take weight / tension off the transmission, which in turn will allow you to turn the steering wheel enough to see if the ignition switch can be turned.
Jun 24, 2017 | 2005 Chevrolet Blazer 4WD
Hi my name is chris i have a 2001 chevy blazer 4x4 for so reason it keeps putting itself into 4x4 when i stop at a light or stop sign and won''t let me put it back into 2 wheel drive ?
There's been a lot of problems with the 4wd systems on the blazers of that vintage. The only sure way to track down the cause is to have the system scanned. Some of the most commom causes are: the switch in the dash, - the control module, - the transfer case . There are other issues if it has auto 4wd as the ABS system is tied into that system to activate it when the sensors sense wheel slippage. If your blazer has the auto 4wd funtion and has a ABS light on, it could be in the ABS system.
IF you could get it back into 2wd, you could pull the fuse to the 4wd to dis-able untill you have a chance to have it scanned.
Jun 24, 2011 | 2001 Chevrolet Blazer
4wd light keeps flashing on 2003 mitsubishi challenger
Hi Adstew,
the front diff has a sensor telling the control unit it when it is engaged (or not). It probably is, and it won't disengage. or the sensor is stuck. The selector lever tells the control unit you want 2WD but the sensor thinks the front axle is engaged. So it flashes.
When shifting to 2WD, normally the front axle will come free after a load change or a bit of turning the steering from side to side, but it sometimes happens that it gets stuck. You can find out:
lift the car free off ground, then select drive forward in 2WD. If the front wheels do not turn, then the sensor may be faulty or stuck. if the front wheels turn in 2WD mode, the diff is stuck and the sensor tells you so. Same or similar problem can happen with the center diff, by the way, on pajero/montero, etc.
regards
Winfried, the perfessa
Jan 18, 2010 | 2003 Mitsubishi Outlander
Cant tell if my front axles are locking in . the light on the dashboard works . the transfer case locks in its a 1996 ford explorer xlt
considering its winter the best way is to put some thing in front of front tires and try to move forwards if you cant put it in 4 wheel mode and then try it. if you climb over then axles are engaged.
Jan 07, 2010 | 1996 Ford Explorer
I have a 2001 montero sport
Hold on your dash is telling you that (active trac) is on. There should be a botton on your dash listed
A/T MODE just push it and the HOLD should go off.
Jan 31, 2009 | 1999 Mitsubishi Montero Sport
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
