Question about ViewSonic VX2433WM 24 inch LCD Monitor
Bad power board
I would get a whining/screeching noise coming from the back of the monitor for about 10 seconds and then the screen would cut out. I thought it might be bad caps and replaced the electrolytics. Firing the monitor back up the same problem occurred. Pulling the covers and shields off and running the monitor bare showed that the noise was coming from the xfmr marked as T501. Is the problem with this xfmr or is something else causing it to make that noise. I can purchase a replacement power board for $30 but would rather try my hand at fixing the board and purchasing a LED monitor.
SOURCE: Viewsonic VX900 Lcd Monitor Bad Power Supply
Go to for complete procedure http://www.lcdpart.com/images/ViewSonic_VX900.pdf
Posted on Oct 10, 2007
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX910 powers on, screen displays for 1 second then turns off
Blinking on and off is not always a capacitor issue, it is usually caused by faulty transistors at the high output transformers that light the backlights. Crappy board design ! But fixable in most cases.
Posted on Aug 10, 2008
SOURCE: screen won't stay on
I had the same problem and called Viewsonic (www.viewsonic.com). Bought mine in July '06 and to my surprise it's still under warranty. The warranty goes for 3 years so even though shipping is my cost, they'll fix or replace it with a same/similar model.
Posted on Jan 05, 2009
  • 144 Answers
SOURCE: Viewsonic VP2130b monitor no post black screen
Here is a suggestion:
By looking at the power board you should see the light, and where it is connected to, so diagnose the circut from that point foreward eliminating any potential of damging the board. try any cables or ribbons.
Posted on Jun 20, 2009
  • 1684 Answers
SOURCE: ViewSonic Vx924 No power
If youcan take a picture or two of the boards in your system as close and clear as you can and go to our web page and email them to me I will check and see if we can help you find the problem.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 14, 2009
Hi my c1 has started to make a whining sound (bit like a dog whine) the last couple of days. It tends to get louder and is intermittent, it starts when the engine is fired up (no probs starting engine)...
Have your drive belt replaced (sometimes called the auxiliary or serpentine belt) when it slips it creates a screeching noise and it's also a sign that it's going to fail (snap).
These can run the alternator and power steering so you should change it as a preventative measure.
Oct 17, 2013 | 2008 Citroen C1 1.0
My power steering pump pulley is making a terrible noise, it just started sunday and we have just replaced the idler and ac by pass pulley. The power steering pulley noise comes and goes...?
It sounds like the power steering pump itself is bad. You mentioned changing the pulleys. Does the vehicle screech or whine when turning the wheel in a parked position? There is also what is called the power steering gear box. They do sometimes go bad as well. I would also look for any leaks in the power steering hoses.
Apr 23, 2013 | Cars & Trucks
When the monitor is turned on the screen goes on but there is a buzzing noise coming from the power supply board, then after 3 seconds the monitor goes black but the green power light is still on and the...
Sounds like the common Bad Capacitor story! If your monitor is not under warranty and you have any soldering skills this is only a 10 dollar fix. There are dozens of tutorials on youtube that will walk you through this. Search "Monitor capacitor replacement".
Aug 05, 2011 | HP L1740 17" LCD Monitor
Hi,i have just bought Audi A496 1.8Ltr and power steering makes whining noise but no leak found,please help,thanks & cheers.
if it is whining -- then this is a sign that you need to add power steering fluid to the reservoir.
there will be a hot and cold line on the small dip stick in the reservoir,, it is best to fill while the system is cold,, fill to the cold line and this should stop the whining.
c...
Feb 05, 2011 | 1998 Audi A4
Sounds like whining noise when i start up then it disappears, what could it be?
If the noise increases if you rev the engine suspect the serpentine belt. This would be more of a screech than a whine. The noise would be more pronounced on a moist morning. It comes from the belt slipping or being misaligned. Try a GoodYear Gaterback belt as a replacement. It has grooves cut into it to reduce noise. Be sure your tensioner is working correctly. Also, the starter can make a noise if it does not disengage properly.
Sep 09, 2010 | 2008 Chrysler Pt Cruiser
Screen cutting out
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Hannspree HH251H 25" LCD Monitor
Whining or grinding noise/screech when we turn the wheel
Dear Screech And Whine......What you have described is definitely a power steering concern. And yes the fluid is low.....thanks for the accurate problem description!! You are correct on the filling the fluid part also......but keep in mind that if your power steering fluid is lo that you might very well also have a ps leak too.You can do a visual check and trace all of your ps lines to make sure that no fluid is escaping anywhere.....You ae more tha welcome to get back to me if you have any further questions...HOPE I COULD HELP!!!
Nov 17, 2009 | 2001 Dodge Stratus
I have a dell flat screen monitor that keeps shutting down after about 10 min.. When it comes back I get the message: 1:auto detect analog. I've tried going into COntrol Panel and changing the...
Either a dodgy power supply that keeps getting cut off for brief moments, but long enough to disrupt the power.
Or
A graphics board problem. I've seen multiple compluters runnig 2 screens where the second screen whould randomly go black and come back with the detecting analogue/DVI signal. This was solved by switching to an Nvidia graphics card
Aug 19, 2009 | Dell Computers & Internet
LCD monitor comes on for about 10 seconds then goes off
It sounds like the power supply board on the monitor may be faulty (that or the backlight).
You could test it on another computer to see if does the same thing (or another monitor on your computer).
If the same problem occurs on this LCD you'll either need to get it repaired under warranty, or pay for it to be repaired. Or just throw it out.
Dec 09, 2008 | HP w17e Monitor
Bad lcd
My best guess is that your inverter board is bad. The whine would be from the transformer. Try to search the internet for a replacement inverter board for your monitor.
Jul 15, 2008 | Niko 2206W Monitor
ViewSonic VX2433WM 24 inch LCD Monitor Logo
103 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
