Question about E-Machines Computers & Internet
Processor fan working no display - E-Machines Computers & Internet
    Brigadier General:
  • E-Machines Master
  • 3,400 Answers
Kamal.check the cabels from monitor to computer.the should be seated tight,also the videocard should seated tight in the slot.
or the videocard may be brooken.
Posted on Apr 23, 2013
Compaq presario sr5000 no power but fans run cd rom opens and closes.
First check the processor fan is working if working remove the memory from the slot clean with a clean cloth and rub the conector with a erasor dont use any metel or any other thing insert the memory and see if the lock is locked on to memory properly still not working change the memory sutable for the memory slot still not working removce the processor heatsink and the processor clean the surface and apply athin layer of heat sink compound and fix back the processor if still not working change the processor if still not working use an addon graphics card and check for display
Oct 27, 2011 | Compaq Presario 5000 PC Desktop
Its display for only 3-4 minutes when we start and the display go againa
remove the processor heatsink and the processor clean the surface and apply a thin layer of heat sink compound and fix back the processor and also check the processor fan is working if the processor is fauly the processor heats up quickly and shutdown the computer
Sep 02, 2011 | Computers & Internet
Giv no display
The pc is starting up well withot the startup sound and has no display with both flat screen and the crt monitors.
Aug 10, 2011 | Compaq (137365-002) Pentium III, 667 MHz...
My HP monitor, connected to CPU does not display anything on the screen but the power is on, showing yellow and green colour (blinking).
first remove the cover switch of the computer and check the cable from the monitor to the computer is connected properly then check wethe the smps is working then check wether the processor fan is working if working remove the meomery card and clean with a clean cloth and also remove the processor heat sink and clean both surface of the heatsink and the processor and lay a thin layer of heat sink solvet and replace the processor fan firmly to the processor and switch on the computer
Mar 26, 2011 | Computers & Internet
Hi! My Hp Pavillion a1710n desktop emits a series of never ending beeps every time I turn it on, and nothing appears on the monitor. I checked and the monitor is plugged in. I dont know what's going on.
The problem with RAM or DISplay card(It can be Moisture problem) or Processor Fan is not working properly. Open the CPU case, locate RAM, remove the ram by opening the both side clips. and put the RAM back as it is. If you have Graphics card on your CPU then remove the Graphics Card also and put it back as it is. Start the PC with opened case to check Processor Fan is Rotating or not. If Fan is not working properly then you have to replace the Processor FAN. Fan ok but same problem persists. you have to replace RAM with new one. as well as Graphics (Display) card.
Jan 19, 2011 | HP Pavilion A1710N Desktop PC
No display loose connection between processor and motherboard
open ur cpu and check connection of processor and clean the RAM
Apr 28, 2009 | Intel Desktop Board D845BG (KD845BGPAK10)...
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
My asus eee is not switching on, the screen is flickering on and off but nothing is being displayed on the screen and it isnt coming on...
That problem is from the processor fan not working in which will have affected your processor itself ok try and replaced the processor fan if its not working and if affected by the processor you will need to change that too for normal and adequate functioning of the system .ok
Rate this solution
Nov 27, 2008 | Computers & Internet
Can u help me?
check the video card of your system. if it is add on card , remove it and clean. if still error exist then maybe u need another VGA.
Jan 10, 2008 | Asrock 775VM800 Motherboard
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
