Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
About four weeks ago, I had the tv on for about 2 hours and suddenly the picture started having bright white flashes in it and then the fan died down and picture went to black (still had sound). I waited for about a minute and then the wound back up and picture came back on. Worked great for about 15 minutes and then did the same. Since then this is what it continues to do. If I turn it off before the pic goes out and leave it off for about ten minutes, I can view for about 30 minutes before it starts happening again. RCA tech said it was my bulb. I replaced it and it still does it. Please help!
  • Anonymous Nov 17, 2007
    Mine does the same thing but everyone says thers some noise if your color wheel is failing? dont know but if you did it and it worked can you please reply so i can be sure and i can get to fixing mine thank you.
  • MARGARITO22 Apr 26, 2008
    I HAVE THE SAME PROBLEM WITH MY RCA 61 IN TV IT COMES AND GOES I STILL HERE THE SOUND AND IN MY CASE I DO HEAR THE SOUND IN BACK OF THE TV
Sounds like another crappy color wheel issue, just like my samsung hln617w.
Posted on Sep 05, 2007
Samsung HLN617W No Sound. As I turn on the TV, the speakers give off a "sputtering" noise that can barely be heard. After a while the speakers come on. But, what used to take five minutes (2...
Red light comes on but then the tv is playing but after about 3 hours it just goes out but I can still hear the sound then if I go back after about 4 to 5 hours if I turn it on it plays no problem. Now the lamp just went. I think before replacing the lamp maybe I should replace cooling fan also.
Jun 07, 2011 | Samsung HLN617W 61" Rear Projection HDTV
I'd like to know where I can get a replacement wire to connect the lamp ballast to the J4 input in my rca HD61LPW42 rear projection TV. I've gotten no response to an email I sent RCA a week ago. These...
hey mcd5brady, what was the solution to your last problem w the tv? ( replaced bulb and ballast but still no picture) my tv has same problem and dont know what to do next. any info on a solution would be greatly appreciated! post back or email. dellbino@aol.com
thanks
Jan 09, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
My rca tv model no r52wh74 goes off after a few minutes and wont come on until about 10 minutes then goes back off again?
What the problem is here is you have a bad power supply or you need to do a hard reboot. On this tv to reboot you need to unplug it from the wall and leave it unplugged for about four hours if not you need a power supply
Nov 20, 2009 | RCA R52WH73 Projection Television
RCA HD61LPW42
How about the fan? I had a problem where the picture would not come on for a while and I noticed the fan speed fluctuating. There must be some saftey that keeps the bulb off if the fan isn't running. When I finally had to replace the bulb, the problem ceased.
Nov 09, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
36" RCA TV
My RCA G36788LV 36" television won't turn on
Oct 30, 2007 | RCA G36788LV 36" TV
Picture flickers, loses color, goes green, white, and negative, then TV turns off.
the unit has a bad color wheel.rca has seen this problem before.The color wheel has a bad bearing which over time can seize causing the single color you see.Keep on them they know it is defective
Mar 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
What to do?
This unit also has ballast problems.You most likely will need to call a tech for replacment.
Mar 02, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
144 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
