Question about Nvidia Asus A7n266-vm Amd Socket 462 Motherboard
Machine making weird sound
Onboard audio not working
On Board audio not working
Posted on Apr 24, 2013
I recently purchased a new M-Audio Audiophile 192 sound card but I cannot get it to work, I don't hear anything coming from my speakers (M-Audio AV40s), which I know are working because I tested them...
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
Sep 16, 2011 | M-Audio Audiophile 192 Sound Card
Nosound
I am going to just have a few guesses at your problem as "nosound" doesnt really clarify it enough =]
If your onboard sound isnt working, You could try looking for an audio driver for this particular motherboard. Google "Intel D865GRH Onboard Sound Driver"
If you are using audio ports in a computer Case, make sure they are connected correctly to the motherboard, or use the audio ports on the back of the board.
Onboard sound does break on some of these older boards, Try using an external soundcard. (PCI or AGP) or a USB one. I picked a 7.1ch USB soundcard up off ebay for $8 and it works fine on all my old motherboards.
Hope this helps you, Best of luck.
Jul 11, 2011 | Intel D865GRH (KD865GRHLKPAK10)...
No sound
Please install / re install the driver and check back the sound.
Regards, Jay
Feb 26, 2011 | Computers & Internet
How do I remove a sound card from the Emachine T2482?
hello, i think thi smodel has an onboard AC97 audio chipset. if my asumption is correct, then you can not remove (physically) the chip set.
if you are adding a new card for whatever reason, you can simply disable the onboard audio by going in to BIOS.
simply restart your PC and start hitting delete key ( assuming thats the key to get into BIOS) and once in the BIOS find area called onboard peripherals and locate onboard audio/sound and disable it.
technically you don't have to disable it to get another card working but to keep things simple i would recommend you do that.
hope this helps
kind regards
Amar Sondhi
Dec 05, 2009 | E-Machines T2482 PC Desktop
Speakers doesnt play
check the motherboard manual and see if it requires a jumper to enable the audio onboard ( if so get the jumper from your motherboard box and seat it on the correct jumpers in the correct position to enable onboard audio ( assuming its onboard audio that you are using ) If not then ensure your sound card is seated firmly and install the correct drivers ( for either the onboard audio or the dedicated sound card ) and then ensure that the speaker cables are connected to the correct connectors on the sound card ( whether onboard or not ) and make sure windows audio is not muted for any of the auxilary lines ie wave etc and if its realtek ensure that you have 2 speakers selected in the HD Control panel and not head phones.
May 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have no audio
did you do the drivers? does the sound blaster have the drivers?if the onboard failed the add on should work, if it's not broken. make sure you have the right driver. you can download them on creative labs website, or asus website for that board, but disable the onboard if you use the add in sound blaster. this should work, if you had sound before, also make sure no conflicts with sound devices. hope thi helps happy new year..
Jan 01, 2009 | ASUS K8V-SE Deluxe Motherboard
Sound card won't work with external input
Are you trying to record and listen at the same time? It doesn't usually work that way, the computer has to process and encode the audio signals before they can be listened to. Once you restore the computer, are you able to listen to the recording? If you have onboard sound, rather than a separate sound card, all the audio processing is done by your CPU. If you are trying to listen to the audio as it is being recorded, you are probably overloading the capabilities of the device and its shutting itself down. Try to record without listening. Also make sure you have the latest drivers. If it is onboard audio, check the manufacturer's website for updates. If you know that it is Realtek AC 97 (probably says so your manual), you can download new drivers from the Realtek website.
Dec 09, 2008 | E-Machines emachines (emachinees) CD-ROM...
Sound card
As Acqwerty says, check your audio volume first, put the volume on everything up. Do you have an onboard or seperate sound card? If its onboard you have to make sure its enabled, this is done in the control panel, sound/audio devices. If its a card you put it, check the drivers, and make sure there are no other cards running on the same port as your soundcard, also done in control panel.
Dec 05, 2008 | E-Machines eMachines Desktop PC
No audio output
Is the audio device onboard, or do you have an addon card? If it is onboard, I will need the make and model of your computer to find the driver.
Apr 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
Nvidia Asus A7n266-vm Amd Socket 462 Motherboard Logo
23 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
