Question about Microwave Ovens
Sharp r 8476 Carousel Microwave Oven
NO Panel Display
MicrowaveSvc
  • 9098 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: Sharp microwave oven LCD display malfunctions
Might or might not work. IT worked for me.
This is a common problem. i havent completly solved it yet but this helps.
Be very careful doing this, There is Voltages with AMPERAGES high enough to boil your blood inside a microwave.
I had mine apart cleaning it. Only one number worked on my display. I wiggled and messed around with the wires in the back of the display. And almost every number in the display works again. Hope this helps.
Posted on Mar 07, 2009
  • 38 Answers
SOURCE: Hi our Sahrp Carousel microwave LCD panle display is not working
You have to replace the control board. Sharp has had problems with the display boards for awhile. There is no bulb or fuse you can change.
Posted on Mar 15, 2009
  • 71 Answers
SOURCE: Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Posted on Jun 11, 2009
  • 574 Answers
SOURCE: Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Posted on Sep 17, 2009
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
How do i remove the display on a sharp carousel microwave in order to get roaches out?
Take of the main cover and turn upside down and give it a good shake to clean out.
Jan 09, 2015 | Sharp Carousel R530EST Microwave Oven
Touch screen panel not working. in past unplugged and then plugged in again and it worked but now nothing
If you mean the display (the microwave works but no info on display) look here for a good diy thread:
http://nzlamb.wordpress.com/2010/04/10/sharp-carousel-microwave-lcd-repair/
Aug 12, 2011 | Sharp R-1750 Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
May 07, 2009 | Sharp Microwave Ovens
Sharp carousel R1754 microwave...display screen keeps scrambling
Stay away from Microwavedisplay.com and William E Miller. He will take your money and will not return your display unit let alone repairing it. Do your research. There are a lot of us out there!!!
Dec 27, 2008 | Sharp R-1750 Microwave Oven
Sharp Carousel Microwave oven
Assuming the unit works ok other than the display, you have a problem common to many Sharp models.
Check with www.microwavedisplay.com - lots of info on this issue and they offer a repair service for the boards at a very reasonable price.
Jul 10, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
