Screen The screen is not working
    New Friend:
Unplug it for 24 Howers Remove Battery then restart it!
Afterwards it should work!
Posted on Apr 23, 2013
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
My touch screen is not working frequently. Give me the solution? How to restore my phone when touch screen is not working
Hello there,
If your touch screen is not working frequently, what you have to do is to calibrate the screen or check for the touch screen sensitivity. To calibrate the screen, go to the menu of the phone and select the settings, from the settings select the screen option, then you select calibrate screen and follow the rest of the instruction there on, or you select the touch screen sensitivity and increase it from there.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Nokia 5250 Cell Phone
I have a samsung f480 i but the screen is damaged on one side, but still works..... can i replace it with a normal f480 screen ? i have done so but the screen does not work ?
dear , if your screen still working after one side damaged , so thats great , but unfortuntly , its not work for more days . one day it i will damaged the whole screen ,so my suggestion is that.. purchase branded screen and replace the screen...
Jul 22, 2011 | Cell Phones
Hi! The touch screen on my Garmin nuvi 660 is not working. On boot up I can't get past the reminder to update map data screen. I have updated the unit software and tried to recalibrate the screen. As is...
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then calibrate the screen, to calibrate the screen, screen calibration do not just work once you do it, you have to do it over time for it to work. Ensure you are calibrating properly. These are the proper steps to follow when trying to calibrate the screen:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
Try this repeatedly till you get it to work. If it does not work, then it means there is an internal problem that need to be checked by a repairman.That should do the job for you.
hope this helps.
Dec 26, 2010 | Garmin Nuvi 660 GPS Receiver
Touch screen not working
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Black lcd screen
Does the phone still work? can you make calls? If so, yes, a screen replacement will work.
A white screen usually means no signal is being received by the screen. A black screen means the lcd back light probably died.
sidekick LCD screens
Jan 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
take the battery off for 15 seconds and try to put it back again. goodluck
Dec 22, 2007 | T-Mobile Wing™ Smartphone
Computers & Internet Logo
David Payne
David Payne
