Need help to fix MAG INNOVISION MA-32EF1ASP http://www.maginnovision.com/Products/Product.aspx?sn=468π= 2814 it got no hardware issue for sure some kind of software glitch caused it to not come up after restart below are the sequence of things i did before its failure i did channel scan it got around 150 channels at first it is not saving in channel list after restart so i figured an alternative to press guide while it is in middle of scanning it is saving channel list(around 70 channel) after restart now i guess got more greedy and scanned again now with 150 channels and pressed guide and restarted to check if it saves channels in list now the TV wont come up seems like doing some thing and not able to process when i power it on red led will become blue and lcd bulbs glowing but no startup mag screen(blue screen) and i believe it ran out of memory(or similar) because of channel scan need to reset TV to factory defaults or need to reset TV firmware to factory defaults please let me know how it can be done
SOURCE: MAG Innovision HV 175 Device Code
I have a universal remote from Time Warner cable, and input 1498 as the code and it worked. It all depends on what remote you have but try that number.
Posted on Feb 07, 2009
  • 42 Answers
SOURCE: Mag 32TV LED powers up TV will not.
If you still have the laptop connected to the TV, and it wont power on. disconnect it.
Wehn connect a laptop the output needs to be changed using the Function (FN) and F keys.
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: 1 Magnavox 32" LCD HDTV MAG 32MF337B
Replace your capasitors on the power circuit board.. They are junk to begin with.. They are cheap.. Thats all i can suggest..
Posted on Dec 10, 2010
SOURCE: MAG Model 3200 HDMI Not working
The HDMI socket could have a dry joint or loose connection on the board, as these are usually prone to wearing out.
Posted on Nov 16, 2011
SD Tech
  • 14553 Answers
SOURCE: Why does my MAG Innovision MA-32EF1ASP Flat Screen TV not function properly?
Have your hand ready when you turn the set on and instantly change the input to get back to the tuner in the set--some sets will shut down if hooked to a input with nothing connected.
Also if using a box connected to that input unplug box and set--wait and plug both back up to allow them to reboot.
Let me know what you find--not likely a reset will cure this but possible.
Posted on Apr 03, 2012
Apr 03, 2012 | Televison & Video
Trying to find driver for monitor MAG GML 2427
Here is a link to your Mag monitor driver:
After downloading, just double click the driver icon & follow step by step instructions.
http://www.maginnovision.com/Support/Downloads.aspx?sn=471&dl=0107
Best wishes,
Graemevm
Mar 24, 2011 | Mag Innovision Computers & Internet
I need the cable fo my mag lt1919wd6 monitor
I recommend you email parts@maginnovision.com (Parts). They should be able to help you.
Good Luck!
May 06, 2010 | Mag Innovision Computers & Internet
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
MAG innoscan DTS-3060 on Windows XP
Give this a go
1. Uninstall any twain drivers you have in stalled for your scanner. RESTART
2. Install I/O driver "Port IO" from http://www.driverlinx.com/Software_Products/softwareproducts.htm .....RESTART
Port IO driver
3. Install your twain driver http://www.maginnovision.com/Service_Support/drivers/dts3050.html
RESTART
Twain driver
I must admit I have not tested it, but it seems plausable
Dec 13, 2008 | Mag Innovision Innoscan DTS 3060 Flatbed...
Need driver and users manual for mag innovision lt576c monitor
Download updated drivers and manual from Mag website link here: http://www.maginnovision.com/Support/Downloads.aspx where you select product group, type and model.
May 25, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Maginnovision LCD Monitor
You probably have a bad filter Capacitor in the power supply. Schmatics would help locate the faulty component, also you can tear it apart and look for any water intrusion. My wife cleaned the TV screen with windex and it ran down the screen and into the TV. It destroy a menu button which had to be replaced. It caused unusual simptoms.
NSSMS
Apr 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
MAG Innovision LT456s monitor power issue.
If you ask them nicely they just might tell you, else it's only $5 for a user manual(sorry no luck online); http://www.maginnovision.com/service.htm this link has a picture that maybe shows a power cable going to the bottom right (as you look at it) but it's hard to be sure; http://www.amazon.com/gp/product/customer-images/B0002CF06K/ref=cm_ciu_pdp_images_all/104-1966292-9407907?ie=UTF8&s=electronics#gallery this link shows what the power lead should be like - look for a hole that matches; http://cgi.ebay.ca/AC-power-adapter-for-MAG-innovision-lt456s-14-LCD_W0QQitemZ8824271526QQcategoryZ3698QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Hope this helps, if not ask again :)
Mar 17, 2007 | Mag Innovision lt456s 14" Flat Panel LCD...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
437 people viewed this question
Top Televison & Video Experts
