Question about Hotpoint WMA64 Front Load Washer
Hotpoint WM64 keeps fusing and cutting out
Machine carried out the first part ofd the cycle and then half way thorugh when it starts to spin, the machine cuts out and fuses the trip switch in the main fuse box.
  • 903 Answers
It's possible that one of the carbon brushes have worn down to the bottom and it is sparking on the motor causing it to trip the fuse. It's just one possibility. Have you checked the carbon brushes are connected properly and that they have not 1) worn down and 2) that the wires are connected to them correctly.
Posted on Mar 12, 2009
I am looking for an instruction manual for a Hotpoint Aquarius 1200 WM64 and I can not find one online to download. Can you help?
Please click on the link below to open the owners manual for Hotpoint Aquarius 1200 VM64 in PDF format:
Hotmpoint WM64- Washing Machine
Sep 13, 2011 | Hotpoint Washing Machines
Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
Feb 07, 2009 | Hotpoint Dryers
Aquarius 1200 WM64 - machine does not start
If you already replaced the fuse, next part to inspect is the control board behind the timer.
If that is ok, check the wiring harness, the socket and the power cord.
Feb 03, 2009 | Hotpoint WMA40 Front Load Washer
Machine not spinning after a power cut
machine can be reset unplug from the wall for 5 mins that will reset com board.
Jan 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
My hotpoint wm64 is making a lot of noise on spin
Can someone help me please, I have a Hotpoint WM 64 from last week it gives prob. Works well but when you choose a prog it starts well but during last half (as it reaches the green line which i think it means rinse) it stops then i have to kind of go for an other wash to get the cloths rinse well. Anyone have any idea what is going wrong with the machine..?
Apr 25, 2008 | Washing Machines
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Keeps fusing
It seems like something is prevent tub's free movment. Try to spin the clothes tub by hand and look for a free movment. In case it doesn't move smoothly,maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent its clear spin. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. Be aware you should disconnected the power cable before starting your tests !! Good luck !!!
May 23, 2006 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
324 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
