Question about Samsung SyncMaster T240HD 24" TFT LCD Monitor
Samsung Syncmaster T240HD LCD Turns ON itself suddenly.
My new Samsung Syncmaster T240HD LCD TV/Monitor suddenly turns ON with only sound of the TV channel & nothing on screen and then turns off in 5 seconds. It happens everyday once but at different times.
Thank you in advance.
  • djpencho Apr 06, 2009
    It happened the same thing to me. I turned off the lcd in DTV mode, then i got away and after a little while i heard voices coming from the tv room.
    screen was black (it was off) but sound was on. red light on the touch sensor was blinking.
  • Anonymous Apr 11, 2009
    I just experienced the same problem in DTV mode. Did anyone find a solution?
SOURCE: Sound cuts out for long periods of time
I've just been having this problem (sound cutting out every now and then) and decided to get round it by plugging in some speakers to the headphone socket. While doing it I noticed that the in-built speakers would sprang back into life. Since doing this and getting the sound back I've noticed it hasn't cut out again.
I think there might be a problem in some units with the bit that cuts off the in-built speakers when you plug in external speakers. My proposed solution is to prod a mini-jack from anything into the appropriate socket (on the left of the TV) and wiggle it around until the sound springs back.
Dave
Posted on Feb 06, 2008
tantong
  • 138 Answers
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
yooperbud
  • 8637 Answers
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
  • 16 Answers
SOURCE: i have a samsung lcd-tft monitor (syncmaster
call on 01122222222 and take the number or address form yellow pages
Posted on Dec 22, 2009
Opening samsung t240hd monitor
http://userguideme.org/t240hd-manual-download.html
Dec 09, 2011 | Samsung SyncMaster T240HD 24" TFT LCD...
How to mount samsung t26hd or remove the existing stand?
SAMSUNG T26HD by bsblevy - 10/10/11 11:02 AM HI I HAVE A LCD MODEL SAMSUNG T26HD HE DOESN'T TURN ON, I TRY TO TURN ON WITH THE CONTROL REMOTE ,THE LIGH LED FLASH 4 TIMES AND AFTER I LISTEN A BEEPPPP...BUT THE TV STILL OFF, BLACK SCREEM, IF YOU CAN HELP ME WITH YOUR ANSWER I WILL BE GRATEFULL, THANKS
Aug 28, 2010 | Samsung SyncMaster T240HD 24" TFT LCD...
The screen turns black after turn it on ?
data cable connection may be loose tighten the connection
2. replace the data cable
Aug 13, 2010 | Samsung SyncMaster T240HD 24" TFT LCD...
I have 22" SAMSUNG monitor/TV, which seems to turn on momentarily when it's switched ON and then it goes blank. How do I fix the problem ?
This could be your graphics card too , try plugg it into the onboard GFX , and see if it works, if not it is a fault with the screen unfortunatly , which you will then have to take back to shop .
Thanks
Dec 29, 2009 | Samsung SyncMaster T240HD 24" TFT LCD...
Syncmaster930b problem
http://www.fixya.com/support/t859266-koss_kld2700_lcd_tv_no_picture
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Aug 01, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor turns off suddenly
I HAVE ONE SAME PROBLEM THE CHIP BOARD IS WORN OUT I RANG SAMSUNG AND IF YOU HAVE WARRANTY THEY WILL REPLACE IT IF NOT I GUESS YOUR STUCK WITH IT LIKE ME AND MINE WAS BRAND NEW 7 DAYS OLD BUT I DIDN'T GET A WARRANTY WITH MINE
Jul 02, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster 711p power issue
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
Nov 24, 2007 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung SyncMaster T240HD 24" TFT LCD Monitor Logo
715 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
