Question about Rex RX-518
What type thread do I use for a blindstitch machine?
Can you use the serger thread, regular polyester/cotton as used for garments. Is there a magic number thread?
    Problem Solver:
  • 6 Answers
The short answer is: You can use any type of thread that is suitable for the garment. Regular sewing thread, serger thread, etc.
Longer answer: Some like to use monofilament thread because it is clear and goes with any color, but it is hard on the machine and can actually wear grooves in the thread guides.
I really like to use Gutermann Hemshire U151. It is a fine polyester thread that is very flexible and works great in a blindstitch. I order it from Atlanta Thread and Supply (www.atlantathread.com). Their prices are reasonable and they ship quickly.
Posted on May 04, 2009
What kind of thread do I use for the Expressive 820
You would use sewing machine thread depending on what you are sewing. If you are embroidering, you'd probably want to use embroidery thread. If you are quilting, you would probably use cotton or quilting thread. If you are sewing garments, then you will probably want to use polyester or polyester-wrapped cotton thread.
Be sure you are using the correct needle corresponding with the thread and project. (You don't have to use Schmetz needles, but this is a great guide.) Also, change the needle often to avoid sewing problems.
Schmetz Needles Needle Guide
Dec 12, 2016 | Sewing Machines
WHY does my SINGER 420 xl leave thread loops on the top of my design...I am so sick of this machine..Singer does NOT stand behind their products..I WILL NEVER BUY SINGER AGAIN!
You're probably correct. The new Singers are not what they used to be...Singer was bought out a few years ago and many buyers have registered their regrets and disappointment with the new products and service.
http://evadman.blogspot.com/2011/12/singer-xl-400-futura-sewing-embroidery.html
Most complaints about sewing machine problems concern thread loops under the fabric, which are usually caused by the upper thread. Your problem is not as common. Generally, when thread problems occur on the top of the fabric, it is a bobbin issue.
Try a brand new needle. Make sure the needle, thread, and fabric are compatible. Also, check that the needle is installed correctly.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjV3sKLxKvNAhUjE1IKHdbNDb4QFggkMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles
Remove the thread from the machine. Check that the machine is clean--no lint, dust bunnies, thread pieces in the bobbin area, stuck in the feed dogs, or under the needleplate.
ALWAYS RAISE the presser foot when threading. Rethread the machine from the beginning. Check that the thread path is correct for the upper thread and that the bobbin case is loaded and threaded properly. Use the same thread for both upper and bobbin.
Most machine standard upper tension is set at the midway point. However, this is just a beginning point. The tension differs from one machine to another and may need adjusting depending on the fabric you are sewing.
Retest your machine.
If loops are still forming on the top of the fabric, then the bobbin tension may be too loose. Try tightening the bobbin tension (only 1/8th of a turn at a time!).
Understanding Thread Tension Threads
Sometimes it is a thread issue. Experiment with different brands of thread. Avoid old or bargain bin threads (the thread in bins at the fabric store are not the best, also Coats & Clark may not work well in your machine). Stick with better quality threads, ie Gutermann, Aurofil, Isocord, etc. Be sure to use the type of thread that is suitable for your project, ie do not use embroidery or cotton thread for sewing garment seams unless you want to be embarrassed when the seams start popping... Polyester used to be the bane of sewing projects but is now used for many items because the quality has improved and, in some cases, surpassed the former favorite cotton. Polyester is light weight but strong. Some machines just do better with one brand of thread over another.
You may also consider testing the machine with different types of fabric to see if it performs better with a particular fabric type or weight.
If it continues to be a problem, perhaps the bobbin case is damaged or malfunctioning. If you cannot find the answer to your problem, you may just need to take it for service.
http://jennys-sewing-studio.com/index.php/product-lines/singer-futura-quartet/75-singer-futura-quartet/155-faq-about-the-singer-futura-xl400.html
Jun 15, 2016 | Singer Sewing Machines
So,.what is another thread?
Gutterman, Isacode, Floriani, Superior...
There are a lot of threads. Just depends what purpose you are using it to do--some are embroidery others for for garment sewing, then there is cotton, polyester, rayon, silk...etc.
Jan 22, 2016 | Sewing Machines
Machine wont sew cotton keeps coming out of needle tried everything
Do you mean cotton thread won't work in the machine ? Does polyester thread work ?
Some thread brands are not as good quality as some others. Not knowing what brand thread you have, it is possible the thread itself is causing the problem. .
If other types of thread work in this machine, it is most likely either the particular spool of thread or the brand being low quality that is the problem. I would try a brand new spool of a high quality cotton thread to see if that helps.
Oct 02, 2014 | Brother Sewing Machines
How do I get the stitch length to be consistent? It changes with speed
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Jun 14, 2014 | Brother PC-420
Says check upper thread, but thread not broken. then stitches about 20 stitches and stops again
if it's losing power, you have a short in the machine.....if the stitches are jamming, you need to switch thread type. Many standard machines cannot function with the lightweight polyester threads ( especially the large spools made for sergers) so I recommend using coats and clark dual duty. ....make sure you have the same size thread on the top as you do on your bobbin....hope this helps
Feb 20, 2011 | Baby Lock Ellure
Thread keeps breaking
Check first that you are using premium thread (not the cheaper type that you'd use in an overlocker/serger). Breaking thread could be because of one of the following reasons -
the upper tension is too tight, the machine isn't threaded correctly, the thread doesn't suit the fabric (I had the problem when sewing an item the other day and changed from cotton thread to polyester and it stopped breaking). In your instruction manual check at the back for a troubleshooting section where it should be listed with some solutions.
Jul 08, 2009 | Husqvarna Husky 165
Lost manual
  • I'd satisfied to sew cotton/polyester than silk fabric, match more commonly use needle for cotton is no. 14 and stich no.3
Mar 08, 2009 | Sewing Machines
Rex RX-518 Logo
1,349 people viewed this question
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
Murielle Dumas
Level 1 Expert
Joseph Mueller
Joseph Mueller
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
