Question about Saws
12'' Ryobi miter saw with loose blade
I have a 12'' Ryobi miter saw with a laser. I can make about 25 cuts and then the blade comes loose. I had the laser and bolt replaced and the problem didn't go away.
  • 1 more comment
  • David Ford
    David Ford May 11, 2010
    What is the model number and I will try and find a breakdown. But in the meantime make sure that all your flanges and spacer washers are in place, I would tighten the blade using the spindle lock and UNPLUG the saw and with the spindle lock still engaged and with gloves on see if you can turn the blade by hand. This would indicate either a flange or possibly a blade problem. Let me know
  • Thomas F. Schneider May 11, 2010
    Try putting lock tight on the bolt threads.
  • angel Oct 27, 2012
    I am having the same problem. did all of the above and still having the problem. saw is relativly new. Model TS1552DXL. Parts are in place. Blade is in good shape. Never replaced.
  • 187 Answers
You may need to use lock tight on the threads. Also replace the standard washer with a lock washer if possible.
Posted on May 08, 2009
Ryobi miter saw laser is way off. I can get it parallel, but it's about 1 inch away from the actual cut line. How can I fix the laser side-to-side?
Forget it. The lazer site gets obscured and useless after 5 minutes of cutting. It is the most useless improvement I've seen on a power tool in 40 years.
Feb 22, 2015 | Ryobi 10 In Miter Saw With Laser
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I have the blade bolt off of my ryobi miter saw but the blade wont come off of the spindle
tap the blade on the back side to loosen it off. The wood sap has probably dried out and is acting like a glue on the back flange washer.
Feb 13, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Craftsman miter saw motor runs blade does not rotate.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
Broken lock bolt for the saw blade left hand thred iv,e got the old one out but need a new one ???
RYOBI IS ONE OF THE CHEAPEST BRANDS OF TOOLS YOU CAN BUY.Right next to Black & Decker. You probably won't find one at a local hardware store. Go to Ryobi . com.
Jun 05, 2011 | Ryobi 10 In Miter Saw With Laser
I bought the 10" compound
I have been in the same situation in the past, with a mastercraft miter saw to a point of using playing cards to get that nice tight miter joint. placing the cards between the fence and the piece i was trying to miter.Rioby makes mastercraft all thought they are a good saw they have their limits to the precisions of their cuts. good for fences,decks, stuctural framing ect, were a degree two is not a big thing,but when making furniture or interior trim work or picture frames or hobby craft you need to buy a good pro saw like a dewalt or bosh sliding compoud miter saw they may cost more **** their worth the money they are very precise and will last a life time if taken care of .It will be worth the money when you get that perfect cut every time you use it,it will put the JOY and fun back in your projects and not to mention qualaty in your master pieces.
Apr 01, 2011 | Ryobi 10 In Miter Saw With Laser
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Saws Logo
729 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
