Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
Washer will fill and drain. Washer will not agitate or spin, but I can here the motor running.
  • 1 more comment
  • jmelms27 Jan 03, 2009
    We have a Whirlpool ultimate care HD super capacity plus which will spin with help. It also drips water into the drum even when it is not running. I have replaced the pump and motor before.
  • ringlet Jan 25, 2009
    Washer is having hard time spining. Can't take regular load.
  • Amanda Drew
    Amanda Drew Nov 01, 2017
    That's weird that your washer won't spin or agitate. My own is struggling too. It will spin, but the soap refuses to go into it. So the clothes don't actually get cleaned. The two of us should probably just find someone who does washer repair to fix our problems. http://www.acfastappliance.com/appliance...
    Genius:
  • 1,239 Answers
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Posted on Jan 07, 2009
  • Guan Yang
    Guan Yang Oct 08, 2011
    I Have the same problem. Do you have the part number for the gearbox?
Posted on Jan 03, 2009
    Top Expert:
  • Whirlpool Master
  • 6,289 Answers
It's a broken coupler.
Posted on Nov 01, 2017
    New Friend:
My top load Kenmore washer is not spin. The washer and drain works fine. I found a broken "belt" like broken roberish ring on the bottom of the washer. There is not belt on this washer. (part 3 22712). Looks like something between the motor and spin is broken. How can it be fixed?
Posted on Oct 08, 2011
  • 67 Answers
It sound like a belt issue.
  • 641 Answers
It sound like a belt issue. Open machine's cover and check that belt is not broken. Good luck!
Posted on Aug 04, 2007
SOURCE:
Whirlpool ultimate care heavy duty leaks underneath, not agitate or spin. only humms and fills up
Again!! Any washer that does not drain has a bad Drain Pump. Very Common. I see this in 40-50% of the problems. Replace the drain pump and your washer will be very happy
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 19, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
May 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer doesn't agitate
I would like to raplace the damaged part if possible
Dec 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Jul 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,396 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
