Question about Philips 25PS40S 25" TV
Philips TV set PC7225-PC121
How to rset the chanel without remote control?
    New Friend:
  • 16 Answers
Fiessnally found my menu buttons by accident and plain *** stubborn-ness for some reason i pushed and held down the twoo far right buttons. the channels changers . with the set off. and bam the set came on and the menu came up. how cheap of phillips to not put a menu button on a set.
Posted on Oct 04, 2011
This suggestion pointed me in the right direction. I have a 10 year old Philips 27 inch and wanted to add the cable channels. It was a used tv and first I checked cable and it said no, I changed no to yes, and then went to the autoprogram, and all the channels for cable were set. Thanks very much.
Posted on Sep 30, 2007
    New Friend:
  • 76 Answers
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Posted on Aug 24, 2007
SOURCE:
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Televison & Video
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
I have got a sony trinitron tv, without a remote control, i can i set up tv chanels without remote?
there is hundreds off universal remotes out there and yes they do work but try to avoid the cheeper models as they can be verry dificult to set up hope this helps you
Jun 13, 2010 | Televison & Video
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
Sep 28, 2009 | Televison & Video
Remote such automaticaly
Looks like a jammed "channel up" (P+ , CH+ or similar) button on your remote. Try disassembling the remote and cleaning the rubber pads with some ethyl alcohol and cottonwool. Also clean the pads on the circuit board which come in contact with the buttons pressed.
If your TV set has channel up/down buttons on the front panel, it could be that one of these is jammed instead (could also be something else, i just suggested the most likely solution i could think of).
I hope this helps somehow...
regards
3rq8 (Triarcuate)
Jul 23, 2009 | RCA Universal Remote Control
How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
Jun 03, 2009 | Televison & Video
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Help
you'll need to bring up the menu, under "channels" or "set-up" you will find something called autotune (or manual channel set-up). it will automatically set the channels you pick up.
May 28, 2008 | Philips Magnavox 20MC4304 20 in....
Tv set on video
use any remote control go menu and then pres auto progam or pres any chanel like #2 or chanel 4 for exemple on tv
JOSE
Dec 22, 2007 | Sanyo DS19310 19" TV
Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Dec 08, 2007 | Televison & Video
Philips 25PS40S 25" TV Logo
310 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
