Question about Whirlpool Washing Machines
LT5000XMNO thin twin washer dryer
Plastic ring like thing (sheild) on top of tub flys around during spin cycle.. need skematics to see what part is called.. or is there clips??
  • 13433 Answers
SOURCE: washer/dryer combo spin cycle.
Hey,
Have a look here,
http://www.repairclinic.com/0088_11_1.asp
your problem is on the list, also replacement parts are available from
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Let me know if you need more help
Thanks,
Ekse
Posted on Sep 10, 2008
agitateme
  • 88 Answers
SOURCE: Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
Posted on Sep 18, 2008
Maytag317
  • 1136 Answers
SOURCE: Kenmore Elite Top Load does not spin on spin cycle
Hi, If the inner tub has dropped down, you will need to change the block that holds the tub to the shaft. Remove the agitator cap and then use a 7/16" socket to remove the bolt holding the agitator in.
Lift the agitator out and look at the block holding the inner tub. There should be two slots with two tabs sticking up inside them. You will probably see metal shaving as well.
If this is what you see, please let me know and I can direct you on further repair.
Thanks
Vic
Posted on May 30, 2009
  • 254 Answers
SOURCE: Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Posted on Feb 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Makes banging sound during agatation cycle, tub and agator both rotate back and forth.
Lift the top cover of the unit from the front of the unit once it is free from the front locking clips, which hold the cover in place. Two things you need to inspect for damage. 1) You should see four rubber straps, which should restrict the movement during the wash and spin cycle (cost is around $4.00 each). 2) Check the shocks on the tub support rods and plastic hardware for damage.
Feb 21, 2011 | Hotpoint VWSR4160GWW Top Load Washer
Washer/dryer combo spin cycle.
the clutch bearing must be gone worn out
Sep 10, 2008 | Washing Machines
I tried washing a rug - I believe it was too heavy and moved the washer around during the spin cycle. Now it is not spinning, it make the sound but it won't turn - I can move the tub around with my hand...
Hello- First unplug the washer. The out-of-balance switch may have gotten tripped. If you open the lid and look in the space between the tub and the top in the rear right corner you should see a plastic "arm" sticking down, reach you hand back there and move it back away from the tub. This lever actuates a switch in the control panel that will prevent it from spinning if there is pressure on it, it should be hanging freely away from the tub. Plug the machine back in and test it. If it doesn't work another thing that may be happening is the tub is not engaging on the transmission. With the tub empty reach inside the top perimeter of the tub and lift it up and let it down a few times, sometimes this will reset it and get it to spin. Lastly, i would check that the lid is locking when you put it into spin, the lid lock light should come on and you should not be able to lift the lid. If the lid is not locking you may need to have a F/P Tech out to replace the lid lock. You can test the spin by setting the machine to Permanent Press and advancing the cycle to spin. It will take a few minutes to start spinning usually. Let me know what you discover, good luck. Best regards.
Sep 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Clothing in between tub and will not spin at high speed on spin cycle i think i need to remove agitator to remove whatever is stuck around shaft and tub
Remove the cabinet.
Remove the plastic ring snapped to the outer tub.
Use a wire coat hanger to remove the garment.
Replace the plastic ring and the cabinet.
Mar 09, 2009 | Kenmore 22422 Top Load Washer
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Unstable tub
There are springs inside the unit that stablize the tub during spin. If the springs are not attached correctly the tub will be off balance. Sometimes the Balance Ring loses it's fluid due to a crack or leak and the washer will spin off balance. THis requires a service tech to dissemble the machine.
Nov 27, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool twin thin
You need to check the suspension of the washer, it could be pads, suspension springs, or even the shocks.
Jul 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
