The washer leaks somewhere out the bottom of the machine durring the spin cycle. I have drained the hose and cleaned out the debrit collector. Even with nothing in the washer I can run the spin cycle and it starts leaking.
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Was this solution helpful? Show your Appreciation by rating it:
