Question about Garden
Need to know where the switched side of the ignition switch is wired to. Not sure if the wire fell off or just missing something obvious. Chainsaw does not spark. Suspect faulty Magneto coil as well.
Need to know where the switched side of the ignition switch is wired to. Not sure if the wire fell off or just missing something obvious. Chainsaw does not spark. Suspect faulty Magneto coil as well. However need to start somewhere!
    Problem Solver:
  • 17 Answers
That is just a ground wire. And like you said it just closes the circuit. And it doesn't matter what side either wire go to on the switch. I assume you bought a new spark plug. If not i recommend that
Posted on May 02, 2013
dontbother10
  • 2220 Answers
SOURCE: Magneto wires got ripped out.
Arboristsite dot com. Please do a search to see if your question has been asked before you post. Lou
Posted on Sep 02, 2009
dontbother10
  • 2220 Answers
SOURCE: wanted coil ignition module for Husqvarna 394xp chainsaw
I found an IPL for your saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 394 as model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I chose the 92-10. The coil and wire were manufactured as separate pieces. I found both at Jacks Small engines. It is interesting that the same ignition wire fits a Poulan at 1/2 the cost. About $86 for both pieces at Jacks. HTH
Lou
Posted on Oct 19, 2009
Testimonial: "Most interesting and very helpful Thank You"
  • 4088 Answers
SOURCE: It's about Husqvarna 345 chainsaw.
The easiest way to test is on the machine. Remove the ignition switch wire from the module coil. Check the pole gaps of the module by inserting a thin business card into the gaps after turning the flywheel magnets under the module. Loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel slightly to release the card. Turn the flywheel one full turn to make sure the gaps don't close up further. Use a fresh spark plug gapped at 0.020" and try for spark. If nothing, replace the module. This gets around measuring resistances while trying to evaluate the module. Hope this helps!
Posted on Nov 21, 2010
roadtech7
  • 297 Answers
SOURCE: no spark on homelite 330
The switch grounds the coil and kills the spark. Make sure you dont have a rub through on the wire coming from the coil. Better yet disconnect the coil wire. If this works you will have spark but wont be able to shut it down. Verify good spark, then repair the wire.
Hope this helps, Matt
Posted on Dec 13, 2010
wentlanv
  • 710 Answers
SOURCE: My Makita DCS520i chainsaw will not shut off. I
OK. The kill switch breaks the circuit to the plug. Since you replaced the kill switch, assuming it is good (did you test it with a multimeter?), the problem has to be in the wiring to the plug from the switch. If the plug gets power all the time, then the circuit is complete all the time.
I'd replace the wires from the switch to the plug.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 26, 2011
I have a husqvarna 455 rancher chainsaw aND NEED TO KNOW WHERE TO CONNECT THE KILL SWITCH WIRE THAT COMES FROM THE IGNITION MODULE
generally the wire goes to the kill switch which in turn is screwed down to the body of the saw creating a ground when switched to the off position
Oct 13, 2013 | Garden
Husqvarna 359 - No Spark
remove the side cover and then the small wire to the coil check for spark again if still no spark the coil is bad if you get spark back the problem is the switch or wiring
Oct 04, 2012 | Husqvarna Garden
I have a wire that pulled off, somewhere around the air filter. Can't seem to find where it should re-attach.
The only wire in that vicinity would be the ignition switch wire--expose the flywheel/ignition module by removing the starter/side cover and check the ignition module--there should be a wire coming from a dis-connect terminal going to the ignition switch. Hope this helps!
Aug 11, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
This chainsaw hasn't been started for several years. I pulled the spark plug and it isn't getting any spark. This mdoel has an on off switch.
First check for a disconnected wire at the switch. If that checks out ok,follow the wire from the switch to the ignition module(also called the coil). Most saws use the on/off switch to complete a circuit to ground to kill the engine. If the wire to the ignition module is missing the insulation and grounding to the body that will keep the saw from providing spark.
If all the wires and the switch proves ok you may have a bad module.
May 17, 2010 | Garden
New starter switch for a husky 61
The switch grounds the ignition coil through the spade connection to stop the engine. The switch should be mounted in a metal panel (ground). Hope this helps!
Apr 17, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I replaceed spark plug,and still on spark. Whats next? (poulan 4218) chainsaw
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Apr 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fr2.0 14'' McCulloch chainsaw has no spark when holding spark plug wire while pulling the cord.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
If you really sure there is no spark turn on the ignition, put your pinky finger in place of the plug, and give a short pull. If you didn't get shocked the coil, switch, or wiring is bad.
You can find an IPL for your saw here:
McCulloch International
http://www.mcculloch.biz/
The model you provided does not cross. A number on your saw will match something. Your coil part number can be found there. HTH
Lou
Oct 15, 2009 | McCulloch Garden
Wire fell off
if it has rubberized covered on the ends of the wire then it does not belong to the dryer but but a underwire from a bra........ ask yoiur wife it she's missing something....
Sep 01, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Ignition wire came lose inside my stihl 210c chainsaw .
28866.png This is the only diagram that is offered for this model but on the multifuntion switch (#33) The wire is layed through the upper part of it with the metal connector sticking out of the left side and once there you will pull the wire to the right until the metal connector is seated in the switch. After this reinstall the switch into the handle houseing and make sure that the contact spring (#24) is sitting on top of the switch and when in the off possition making contact with the metal conector of the wire on the switch.
Mar 15, 2009 | Oregon Scientific Oregon Chainsaw chain...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
