Question about Panasonic Technics Stereo Rack System W/ Cassette Deck, Receiver, 61 Cd Changer, 5 Speaker
Panasonic sa vk825d
THE GEAR WHICH HELPS THE OPENING AND CLOSING OF THE RACKS IS BROKEN. WHERE CAN I GET THE GEARS?
Panasonic SA-PT460 disc tray don't opening
The tray mechanism tracks may be binding or the mechanism may lack sufficient power to move the tray.
Dec 30, 2013 | Audio Players & Recorders
Rear AC / heating thumping sound
Yes the noise can be gear "jump" over, the teeth don't break since they are nylon in most cases. This is most often caused by a sticking/warped air temperature control blend door.
Apr 20, 2017 | 2004 Ford Expedition
CD player door not opening
The gears are jammed, or the timing gear is out of sync, and possibily a bad loading belt.
May 20, 2012 | Philips Audio Players & Recorders
Home theatre (panasonic SA-PT460) drive wont open makes some noise when i press the open/close button as its closing. I unscrewed the device and removed the dvd tray from its case as i pressed the...
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
If anyone has a solution I would be grateful.
Sep 08, 2011 | Panasonic SA-PT460
On my camera when i turn it on the lens keeps opening and closing and on my screen it says "turn off and on again" and when i do that the lens keeps opening and closing and it doesn't work. Can you help me...
This is the most common problem with dig cameras. The reason being that there are tiny gears inside the lens assembly, that operate it. When a tooth gets broken off, or some dirt, lint, sand, etc., gets in the lens assembly, a gear can get jammed. When this happens, the camera cannot "initialize" and be ready to take pictures. There is an excellent blog about this problem. It is listed under the lens error category, but it applies to all lens malfunctions, and the one you're having. Here it is:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Try their suggestions. They say about 50% of the cameras can be fixed trying their free fixes. If nothing works for you, and you decide to have it repaired, get an estimate first. The cost of repair can easily exceed the cost of a new camera. Good luck, and hope this helps!
Jun 18, 2010 | Cameras
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
Dec 19, 2009 | Panasonic Home Theater System System
When using camera, the lens will not come completely open or clos
You have broken last (black) gear in opening/closing mechanism. Common problem. Need new gear or fix missing "tooth".
Sep 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Non Responsive Buttons
Hello..
Is this system one that has speaker connections?
If so, all the speakers must be connected for it to work right.
Apr 09, 2009 | Panasonic Electronics - Others
SA-HT740 Broken gear
You probably can get the parts from Tritronics, but as far as I know, there aren't hard-copy manuals normally made for any of the newer products. The only paper available nowadays are the users manuals... The service manuals are on-line at Panasonic and available only to authorized repair centers. Sorry.
I'm curious - how in the heck did a gear break in the thing??? There's nothing strong enough in the drive system to do that (either the motors would sieze or belts slip).
Bugman Mark
Nov 01, 2008 | Panasonic SC-HT740 System
5CD changer SA-Ak640 will not open disc trays just diplays "CHGR ERR" is locked on disc 5
The loading mechanism has jammed somehow. When powered on, the unit attempts to get to a known position. If that fails, the message you indicate is displayed. The only way to resolve this is to dis-assemble the unit and rebuild the mechainsm. This should NOT be attempted without the service manual. There is a particular way to re-assemble these so that the gearing is correct. There are small gears and levers that need to be aligned properly. Also, there may be a broken lever or gear that needs to be replaced. I have rbuilt a number of these and the parts (if needed) are cheap (<$4 total).
I wold suggest that you bring this to an authorized Panasonic service center.
Dan
Oct 16, 2008 | Panasonic Audio Players & Recorders
Panasonic Technics Stereo Rack System W/ Cassette Deck, Receiver, 61 Cd Changer, 5 Speaker Logo
47 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
