Question about Echo Garden
Split rubber boot on echo edger spark plug wire
I have echo edger pe2400 & the the rubber boot on the spark plug wire split. can just replace the boot or do i need to replace the spark plug wire
3 Suggested Answers
  • 6468 Answers
SOURCE: spark plug wire install on ryobi ss26 edger
if the clip on the end broke off that can be replaced but if its on the coil end you need to replace the coil
Posted on Apr 08, 2012
hunter19_46m
  • 7482 Answers
SOURCE: I have an Echo Edger PE 200. The edger will not idle.
hi rgiles_5050
Adjust your idle speed with the idle screw located on the carb...if that does not solve your problem then take your carb off and clean it again because you have some debris/dirt in the low speed circuit, this time make sure to blow all the jet holes out with compressed air to blow out any wedged in dirt
Please take time to rate me
Bud
Posted on Oct 16, 2012
Echo trimmer wont start, i replaced fuel line and filter, spark plug still wont start
Krissie, there should be two fuel lines. also take the spark plug out and pull the cord a few times to blow out any gas or whatever out of the cylinder. then put the plug in the spark plug boot and pull it a few times holding the plug head next to the engine block to see if it has any spark. if it don't probably the coil or switch is bad, if it has spark put the plug back in and give the opening of the carburetor a squirt of carburetor cleaner and try to start it. it should start then. if it does and dies the carburetor needs to be cleaned or rebuilt.
Dec 03, 2016 | Echo Garden
Echo PE-2601 gas edger gets hot and shuts off, then after cool down starts back up
sounds like the spark plug is breaking down at hot temps. replace it. if that dont work the coil is going bad
Mar 19, 2015 | Echo Pe-2601
Spark plug wire install on ryobi ss26 edger
Apr 07, 2012 | Garden
No spark in 2 stroke engine
If you have checked the switch, the switch wire and fitted a new plug, you must face the fact the ignition unit itself requires replacement ( assuming it has electronic ignition ) if it has contact breaker points you may need to clean/replace the points.
Feb 17, 2012 | Echo Garden
On off switch for a echo gt160ae
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.
Feb 09, 2012 | Garden
Have a honda 11 horse on a north star power washer that has no spark,yes the switch is on.
Cause of no spark can be determined by process of elimination. Good to have a new sparkplug on hand to eliminate plug as fault. So start by replacing plug with new or test plug on mower /edger etc. for spark. If plug ok, then temporarily remove the wire connected to oil alert system (oil alert will ground coil if oil low or dirty). With oil alert unpluged, and no spark suspect sparkplug boot or coil. The sparkplug boot threads on to the spartplug wire and is what actually fits-on to the spark plug. You can test the coil by removing the boot and inserting piece of paperclip wire, or small screw into end of the coil wire and hold close to engine ground while pulling rope. If still no spark suspect coil. If spark, replace the boot. Good luck with repair.
Jul 04, 2011 | Northstar Garden
During operation my Echo SRM??? string trtimmer it will electrically shock me when my arm gets near the spark plug wire.
Hi, the sparkplug cap may have a split in it, you can buy a new one and replace it quite easily. Some caps will still shock you even if not split. Hope this helps, regards Phil.
Jul 01, 2011 | Echo Garden
SRM 2000a echo whipper snipper Not starting tried new spark plug and fuel.
Small engines have three systems. 1-ignition 2-compression 3-fuel
if you have spark at the plug and fuel gets to the engine the issue is in the engine compression system. I recommend pulling off the muffler and looking for scratches or scoring.
If you need to replace parts find a dealer like www.arcolawn.com to assist.
Feb 11, 2011 | Echo Garden
How do I change the spark plugs?
Engine off
Remove one spark plug wire / using correct size spark plug wrench with / rubber boot designed for spark plugs (deep well socket with rubber boot) remove (1) spark plug / gap new replacement spark plug to specs / install replacement spark plug by hand into head of engine /finger tight /using spark plug socket and rachet finish tighting spark plug / tighten just beyond snug being careful to not over tighten and breaking spark plug ..if in doubt about the proper tighting consult motor manual for torque specs. use torque specs in conjunction with appropiate torque wrench . Re-install removed spark plug wire ...proceed to remaining spark plugs doing one at a time until completed.
Jan 09, 2010 | 2004 Chevrolet Malibu
Echo GT 2000 does not have spark and will not start. Checked fuel lines, ok, replaced spark plug, ok. checked for spark at plug, no spark.
Your ignition module is probably bad. The part may be as much as $35, but you might want to double check.
Jim
Jun 20, 2009 | Echo Garden
Garden Logo
427 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
