Question about Plumbing
Overflow drain when i use my washer yhe drain in the garden backs up and overfows. also my water in my downstairs toilet rises to the top when flushing and is very slow to drain.please could you give me some ideas were to start
  • 247 Answers
Start with the main sewer trap
Posted on Mar 15, 2009
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
www.popularmechanics.com/home/how-to/a4117/4303948/
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
www.toiletology.com/emergenc.shtml
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
Toilet upstairs sometimes drains when the one downstairs is flushed.
It could be a blocked vent.when the downstairs toilet flushes it draws air down the drain with the wastewater. The vent is suppose to supply air to make up for this. If the vent is blocked or there is no vent. Air is drawn from the easiest place ,in this case through the upstairs toilet,drawing the water out of the toilet trap with it. In northern climates the vents sometimes frost shut causing the problem you describe. Hope this helps.
Jan 14, 2014 | Home
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
When I flush my toilet, the water in the bowl rises all the way to the top like it is going to overflow but stops just short of over flowing. Then it drains out but very LITTLE water stays in the bowl. ...
You have some type of obstruction in your drain. Try a plunger when the toilet is still fairly full. The reason the water level is so low is the toilet was finished filling when the water went all the way down. a714b1a.jpg
If you can't get it open with a plunger, a closet auger works well 7163d19.jpg
Aug 17, 2010 | American Standard Cadet 3 Right Height...
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
My toilet overflowed and I had some water in the washer when I turned the valve off on toilet it stop overflowing and when I turned the washer on spin cycle it emptied the toilet. However, there is still 5...
The emptying of your washer caused suction through the sewer and cleared the clog of the toilet for you. Odd but possible. You do not have sewage in your washer though. Run through rinse cylce to clear out remaining water.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Mar 30, 2009 | Facebook Social Network
Plumbing Logo
197 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
